Author Topic: Made an offer on this today (up grades )  (Read 10582 times)
Offline Mountaynman
  • work from the southern adks to the catskills in NY
Re: Made an offer on this today
« Reply #20 on: March 10, 2020, 07:38:21 AM »
I will also agree with what an animal those machines are backed into an amish customer with a load of larch for his mill about this time of year and as i was unloading the frost gave way and the truck sank to the axles yup all of them the steers were still up and he says i can pull you out with my skid steer kind of chuckled and called a buddy for help. He comes roarin up with his machine 12" axle extensions, tractor tires and chained up , he had picked up a pallet of fence posts for extra weight that thing just squatted and pulled me out like something ive never seen before amazing said it handles 2 ton all the time
Semi Retired too old and fat to wade thru waist deep snow hand choppin anymore
Online Bruno of NH
« Reply #21 on: March 10, 2020, 08:09:02 AM »
I have an extra set of rims and tires.
My brother in law said we should make up dual wheel set up for mud season  :D
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline mike_belben
  • Pulp Friction
« Reply #22 on: March 10, 2020, 07:51:39 PM »
2 ton is nothing for a 9 series. That machine is "rated" for 3700 which i believe is 50% of tip load, so 7400lbs tip which means someone good can probably toe walk 4 ton or so. They ride smooth on 2 wheels and dont tear the ground up either.
;D
Revelation 3:20
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #23 on: March 10, 2020, 09:56:32 PM »
Good score, that will go great around the mill.
Online Bruno of NH
« Reply #24 on: March 11, 2020, 04:53:20 AM »
Belive it or not for such a heavy machine it's light on the ground.
Makes less of a foot print than the 873 I was borrowing.
And the yard is soft.
Online Bruno of NH
« Reply #25 on: March 11, 2020, 05:01:19 AM »
 I know it's old but if I run it right and take care of it.
I hope it will serve me well.
Offline Stephen1
    • muskoka Sawmill
« Reply #26 on: March 11, 2020, 09:16:03 AM »
I have an older 1993 742 with a mitsubishi propane engine,and it has run 7 years for me. I had to do a head gasket and new radiator, but it just runs and runs. I wish it could lift more.
Online Bruno of NH
« Reply #27 on: March 12, 2020, 07:55:08 PM »
Using big Bob around the mill yard.
This thing is a beast.
Offline tacks Y
« Reply #28 on: March 12, 2020, 08:04:27 PM »
Must be a keeper if you already named it. Do you like the fork grapple? I am looking at grapple buckets now.
Online Bruno of NH
« Reply #29 on: March 12, 2020, 08:37:24 PM »
Tacks Y,
Yes I like the fork grapple around the mill yard.
It works good for what I do.
I would also like a root grapple they work great for clean up jobs.
My friend has one.
Offline Banjo picker
« Reply #30 on: March 14, 2020, 06:10:51 PM »
Nice score Bruno.
Offline ehp
  • logger/chainsaw hack
« Reply #31 on: March 14, 2020, 07:13:47 PM »
Bruno that is what I sort on the landing with is a skidsteer , they are fast and quite strong . I got a new S740 yesterday . I have used some of the smaller machines and its surprising on how big of a log they will pick up and move
Online Bruno of NH
« Reply #32 on: March 15, 2020, 09:08:01 AM »
The only issue so far is my other sae quick attach stuff won't fit the quick attach.
I will have to find someone to make a blank plate then have a sae quick attach welded to it.
I can't find anything all ready built.
Offline Stephen1
    • muskoka Sawmill
« Reply #33 on: March 15, 2020, 12:35:42 PM »
Great name. "Big Bob"
Can you post a pic of the fork grapple and the name of it. I really need one at my bush yard, it is very rough terrain.
Online Bruno of NH
Re: Made an offer on this today (update question )
« Reply #34 on: April 07, 2020, 02:05:56 PM »
I'm getting a very strong smell of raw fuel when starting.
When cold starting
It that a glow plug issue ?
Or injectors ?
It runs great otherwise
Thanks Bruno
Online Bruno of NH
« Reply #35 on: April 07, 2020, 02:06:43 PM »
It burns your eyes almost
Offline 51cub
« Reply #36 on: April 07, 2020, 06:23:47 PM »
Easy stuff first. If it's going away as it warms up take a look for wet spots right after you start it. Look around the filter and the lines, check that all the joints are tight , than go from there
I believe in the hereafter, because every time I take two steps into the tool crib to get something I wonder " what did I come in here after"
If nothing else I'm always a good last resort or the guy to hold up as a bad example
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #37 on: April 08, 2020, 12:53:02 PM »
sounds like leaky injectors?
Online Southside
    • White Oak Meadows
« Reply #38 on: April 08, 2020, 10:21:18 PM »
As in the exhaust smells of fuel?  How is the intake line and air cleaner?
White Oak Meadows
Offline chevytaHOE5674
« Reply #39 on: April 09, 2020, 08:42:50 AM »
If the smell is coming from the exhaust after it's been sitting a while I'm going to go with leaky injector('s).
Offer made and accepted - Timber Harvester Sawmill
Started by warren46 on Sawmills and Milling
Last post October 04, 2013, 02:52:41 PM
by Magicman
What I made today
Started by wiam on General Board
Last post June 10, 2005, 11:43:41 AM
by Gilman
I have made saw dust today
Started by alsayyed on Sawmills and Milling
Last post January 02, 2015, 08:30:17 PM
by alsayyed
smiley
Made my first Sawdust today
Started by music_boy on Sawmills and Milling
Last post November 05, 2003, 07:26:31 PM
by music_boy
