Author Topic: 648g jumping into park while moving  (Read 332 times)
Offline Jcutt
« on: March 09, 2020, 03:41:52 PM »
648g started randomly engaging the parking brake today while in motion any help on the issue is greatly appreciated. First post so im not sure where this should go.
Offline nativewolf
  • Forester
Re: 648g jumping into park while moving
« Reply #1 on: March 09, 2020, 07:53:30 PM »
Welcome.  Not an owner of a 648 but there are some on here with experience.  It's a great site and you might want to search the old posts, at least you'll find members that responded to a 648 question.
Liking Walnut
Offline kiko
« Reply #2 on: March 09, 2020, 08:06:55 PM »
Check your brake accumulator.
Offline Jcutt
« Reply #3 on: March 10, 2020, 03:19:46 PM »
The brake accumulator will cause it to do that ? We've been looking along the lines of electrical issues
Offline kiko
« Reply #4 on: March 10, 2020, 06:02:16 PM »
The G does not any computers but it is still circuited so there has to be service brake pressure before it will release parking break . Also the ground for the park brake solonoid is the excitor wire for the starter. It is the white wire on the starter. Make sure that that wire is not corroded or damaged at the starter.  Check the sockets in the fuse box for the park brake relay.  Also the the park brake solonoid is located at the left rear corner under the cab. The block will be marked as to which is which. Also the switch when you go into park is what turns the brake on and off.
Offline Jcutt
« Reply #5 on: March 10, 2020, 06:29:58 PM »
Thanks a bunch for the help. I think we got the parking brake situation figured out it didn't randomly engage today but now its really a pain to start if it stalls takes allot ot messing around with the shifter to get it to start again idk if the park safety switch is going bad or maybe something else is wrong
Offline kiko
« Reply #6 on: March 10, 2020, 06:52:05 PM »
If wiggling the shifter makes things happen it is most likely the park break switch. The shifter handle hits that switch when in park. Also if the shift collar is broken it can have the shift handle not   engaging the switch properly.  Park brake on for engine to start
Offline Jcutt
« Reply #7 on: March 10, 2020, 07:21:10 PM »
Is the collar incorporated with the parking brake switch? I pretty much cut but am fairly mechanically inclined as is my boss and its got us both kinda stumped. Pretty sure it doesn't matter but it being a grapple shouldnt make for other possible issues?
Offline Jcutt
« Reply #8 on: March 10, 2020, 07:22:29 PM »
Not really wiggling lol pretty much gotta slam it back into park. Possibly a linkage adjustment issue?
Park Ranger at Mount St Helens National Park. Deadline is 12/06/05
Started by Stamp on Job Opportunities
Last post November 15, 2005, 09:41:08 AM
by Stamp
648g question
Started by missouri_logger on Forestry and Logging
Last post November 04, 2011, 02:53:00 PM
by kiko
Deere 648G III
Started by labradorguy on Forestry and Logging
Last post February 22, 2019, 10:50:03 AM
by Firewoodjoe
5 Winch 648G
Started by Bobus2003 on Forestry and Logging
Last post May 21, 2010, 11:48:36 PM
by PAFaller
