Author Topic: VERY plesed with my KASCO blades  (Read 767 times)
Offline kelLOGg
« on: March 14, 2020, 09:43:53 PM »
I have pulled 3 blades from the shipment and they are in various stages of cutting, setting and sharpening. I have been cutting pine logs with them and the first thing I have noticed is that they are more flexible any of the 3 brands I have used in the past. There is no sign of gullet cracks in spite of rough treatment (hitting steel and accidently knocking the blade off the wheels by backing up prematurely) and several sharpenings. I am amazed the teeth can be so hard while the body is so flexible. I am pleased with the straightness of the cut. I expect longer life from them before breakage. They are 4 teeth and my sawmill has a 16 HP engine. Did I mention I am pleased?
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline PA_Walnut
Re: VERY plesed with my KASCO blades
« Reply #1 on: March 29, 2020, 10:40:46 AM »
I have Kasco 7 blades on my 40Wide and like them a lot. .055's...they cut well. Only had one break after 3 sharps.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline kelLOGg
« Reply #2 on: June 20, 2020, 06:56:36 AM »
Well, I got long life. My first breakage for a Kasco band after months of use. They are human after all.
Kasco blades
Started by goose63 on Sawmills and Milling
Last post December 10, 2017, 01:24:27 AM
by Crossroads
Kasco Blades
Started by homesteader1972 on Sawmills and Milling
Last post June 30, 2015, 07:49:11 AM
by petefrom bearswamp
Ordering Kasco Blades
Started by LeeB on WoodMaxx Blades from KASCO SharpTech
Last post March 05, 2020, 07:49:49 PM
by kelLOGg
Kasco Blades for a new HM130
Started by nybhh on Sawmills and Milling
Last post January 23, 2018, 09:22:44 PM
by JB Griffin
