Author Topic: Fuel tank storage  (Read 496 times)
Offline Firewoodjoe
  • Im getting old
Fuel tank storage
« on: March 15, 2020, 02:13:42 PM »
I have a 1/4 steel round tank. 72 long 48 diameter. Its a fuel tank but the guy I bought it from had it on wood. It has no legs. Should I weld legs on? Or set it on something? Wood steel concrete? It will be on a concrete slab with a roof over it. Should I worry about rust/moisture between the leg and tank?
Offline Mt406
Re: Fuel tank storage
« Reply #1 on: March 15, 2020, 03:31:07 PM »
Proper welding precautions when welding on a tank that had fuel in it. You may not have to worry about rust anymore.
Were I live it's so dry rust is not a problem. Under a roof I wouldn't think it would  be.
Be careful.
Scott
Online btulloh
« Reply #2 on: March 15, 2020, 03:37:10 PM »
Make a cradle stand. Pipe or steel you have laying around. Strap the tank. Then you dont need to weld on a bomb. Decent paint will take care of the rust problem.
Offline Southside
« Reply #3 on: March 15, 2020, 03:54:09 PM »
In addition to not having to deal with the fuel / welding issue you don't run the risk of creating a future pin hole in the tank, so yes make a cradle and set it on that.
Offline Firewoodjoe
  • Im getting old
« Reply #4 on: March 15, 2020, 05:47:44 PM »
Ive welded lots of diesel tanks. No big deal. I wasnt really worried about a pin hole due to it is 1/4 but the cradle would be simple. And it will be covered. That should help. Thanks.
Online btulloh
« Reply #5 on: March 15, 2020, 05:54:10 PM »
I've never seen a simple fuel tank that size made out of 1/4".  Pretty stout stuff.  What was the original use?  How much does it weigh?
HM126
Offline ljohnsaw
« Reply #6 on: March 15, 2020, 06:08:03 PM »
  And since this is the FF, the cradle should be made out of something like white oak!
Offline chevytaHOE5674
  • Forester
« Reply #7 on: March 15, 2020, 06:23:45 PM »
I'd weld some skids or legs on it so that the tank isn't setting right on the concrete. Gives room for air movement so you dont have any problems with condensation or sweating where the steel and concrete touch.
Offline Firewoodjoe
  • Im getting old
« Reply #8 on: March 15, 2020, 06:48:58 PM »
That was my concern condensation. Ill drag it back out and see what I have for steel. And this was a fuel oil/home heating oil tank made just for this guys house. It was in his basement. Rolled 1/4 tread plate. And it is heavy. Had to get a buddys skid steer because 3 of us could just drag it out of the walk out basement with jacks and wood skid contraptions.
Offline snowstorm
« Reply #9 on: March 16, 2020, 05:45:32 AM »
i have a 550 gal tank that 1/4 thick. the cradle is pt 2x6 on a concrete slab. its been there 20 yrs
Diesel fuel contamination in 518 fuel tank
Started by giant splinter on General Board
Last post February 17, 2013, 07:31:07 AM
by Autocar
046 fuel tank
Started by golden foot on Wanted
Last post January 06, 2010, 11:33:12 AM
by golden foot
fuel tank
Started by coxy on Forestry and Logging
Last post March 11, 2017, 08:15:04 PM
by snowstorm
MF 165 fuel tank
Started by wiam on Wanted
Last post June 06, 2006, 07:28:37 AM
by twoodward15
