Author Topic: 440b skidder winch shaft not turning  (Read 411 times)
Offline Bamalogger1143
  • Member*
« on: March 15, 2020, 07:29:19 PM »
I have a 440 b that the winch was working perfectly and I was pulling a tree and it stopped...realized the shaft had stopped turning...I took the steering section off pulled the plate off the top of the housing where the shaft goes... found a big gear with a small cog under it but don't know what makes it turn...I have no knowledge or experience with this machine...any guidance on where to start
Offline Firewoodjoe
  • Im getting old
Re: 440b skidder winch shaft not turning
« Reply #1 on: March 15, 2020, 07:40:15 PM »
I had a older just straight 440. No letter. And it had a shaft that ran through the bellhousing. It was long 2 foot Iím guessing. Maybe that broke or something. Maybe someone else will have a book or better knowledge
Offline snowstorm
« Reply #2 on: March 16, 2020, 05:40:04 AM »
i have seen this before but it was like 30 yrs ago. 2 snap rings that hold the shift fork. seems like the snap rings  moved and had to remachine the grove
Offline stavebuyer
« Reply #3 on: March 16, 2020, 10:21:28 AM »
The dozers from that era had a roll pin that connected a two piece driveshaft that powered the winch. Looking at the larger outside shaft would be turning and you would barely notice the smaller diameter inside tubing going into the winch was not if that roll pin broke or fell out. Not sure if the skidders are set up the same but think they shared the same winch at that time frame.
Offline Kodiakmac
    • Upper Canada Outfitters
« Reply #4 on: March 16, 2020, 02:09:04 PM »
Have a look at this: https://partscatalog.deere.com/jdrc/sidebyside/equipment/67672/referrer/navigation/pgId/200596
Maybe the splined coupling (part 7) finally wore out?    It generally means the news is not that bad if it stopped all of a sudden without those WTH noises.
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
440JD, Echo CS510, Stihl MS362cm, Stihl 051AV, Wallenstein wx980
Offline Firewoodjoe
  • Im getting old
« Reply #5 on: March 16, 2020, 07:18:55 PM »
Mine did that but squealed real bad from slipping inside the warm splins.
Offline ohiowoodchuck
« Reply #6 on: March 16, 2020, 09:42:57 PM »
I had to replace the coupling and the shaft on mine. It would still turn but if you tried to load the winch it would slip. Both sets of splines were shot.
Education is the best defense against the media.
440b winch driveline and winch questions
Started by ohiowoodchuck on Forestry and Logging
Last post December 31, 2016, 02:46:51 PM
by ohiowoodchuck
440b winch
Started by OldTimbercutter on Forestry and Logging
Last post March 22, 2015, 10:11:53 PM
by so il logger
Pulling a winch off a JD 440B
Started by grassfed on Forestry and Logging
Last post November 26, 2008, 10:29:30 AM
by PAFaller
440b winch problems
Started by Log207 on Forestry and Logging
Last post December 05, 2018, 05:33:58 PM
by sidehill6
