Author Topic: Retro Fitting Clark Ranger 664C  (Read 233 times)
Offline chase.minnaar
  • Member*
« on: March 20, 2020, 05:05:11 AM »
Hello All
Okay, not the typical question, but please bare with me.
I have a Clarke 664C. I have recently overhauled the torque converter and transmission with new parts
from Allied. Ranger is fitted with the DD 353
We have stopped our lumber milling operations and I looking to convert the Ranger to another purpose- I also enjoy these type of projects..
Due to the rangers heavy duty design, weight and weight distribution for pulling, I am milling the idea to adapt the Ranger to a heavy duty Agricultural tractor for the pulling of Feed trailers, Ripping and pulling of a big disk. If I do this, I will need to change the engine and replace with a 120-140kw diesel motor.
My question- can the Torque converter, transmission and drive train handle this type of increase in power? Final drive seem robustly built, so does the trainy. But I cannot find any info online
Cheers and Thanks
Offline Iwawoodwork
Re: Retro Fitting Clark Ranger 664C
« Reply #1 on: March 20, 2020, 07:04:15 PM »
In the 1970's  I operated a 666 Clark skidder with a 4-53 Detroit and I worked it hard in 20" to 40" logs . the 453 had more power than the planetary cover  bolts would take, broke quite a few on the rear. Also had a clutch pac let go, the mechanic thought the snap ring holding the clutches in the cover let go.
I would not repower a 664 with more than a 4-53 or similar hp/torque engine.
Will a 664c Clark Tranny fit a 664b clark ranger skidder?
Started by delimberboy on Forestry and Logging
Last post December 22, 2015, 01:23:05 PM
by oldseabee
Clark Ranger 664C weight.
Started by nhlogga on Forestry and Logging
Last post October 05, 2014, 08:33:27 AM
by riddelin
question
clark 664c
Started by borecutter on Forestry and Logging
Last post February 27, 2014, 03:36:58 PM
by oldseabee
Clark 664C
Started by Chrbat33 on Forestry and Logging
Last post March 30, 2017, 09:58:10 AM
by ClarkF66
