Dynamic Green Products Inc.
Author Topic: Axle hubs for bobcat rims  (Read 630 times)
Offline mjeselskis
« on: March 20, 2020, 11:06:33 AM »
I'm looking to build a walking beam off road trailer to haul behind my tractor for logs, dirt, etc. I have a nice set of 4 skid steer rims and tires that I'd like to use since they are high flotation, strong, and thick. They have a large bolt pattern, I think it's 8 x 10.75", so it doesn't line up with many common hub patterns. Besides making 4 adapter plates, does anyone have any ideas/options for hubs/axles?
2006 WM LT28  1993 John Deere 5300
Offline 711ac
Re: Axle hubs for bobcat rims
« Reply #1 on: April 02, 2020, 09:31:52 AM »
If it's not an odd ball tire size, it may be simpler/cheaper to just look out for some standard 8 bolt (truck) wheels. They would be plenty strong for trailer use vs the constant side forces that you'll have on a SS. Even if they are not quite as wide, a little extra sidewall bulge should help protect the rim some and not make any difference just rolling along in a trailer application.
Offline chevytaHOE5674
« Reply #2 on: April 02, 2020, 02:01:48 PM »
Pretty sure most skid steers are 8 bolt on 8" circle. Check out agrisupply I've seen hubs in that pattern there before.
Offline mike_belben
  • Pulp Friction
« Reply #3 on: April 04, 2020, 07:58:21 PM »
Weld some stock steel junkyard rims right into the center and torch out the old circle.
5 on 4.5 / 5 on 114 is super common.  Jeep cherokee honda accord  camry etc etc.  Then just use junkyard unit bearings or trailer spindles.
I dont know anything that matches a bobcat.
Revelation 3:20
Offline mike_belben
  • Pulp Friction
« Reply #4 on: April 04, 2020, 08:00:10 PM »
Keep in mind a 16.5 skid steer rim has no safety bead and theyll drop a bead any time they leak down or get sidescrubbed too hard.  Keep em aired up good.
Revelation 3:20
Offline sealark37
« Reply #5 on: April 05, 2020, 02:49:00 PM »
Using specialty tires in a different application is fraught with unanticipated problems.  Please don't ask how I found this out.   Regards, Clark
Offline sealark37
« Reply #6 on: April 05, 2020, 02:53:01 PM »
Using specialty tires for a different application is fraught with unanticipated problems.  Please don't ask how I found this out.
Offline mjeselskis
« Reply #7 on: April 05, 2020, 06:33:06 PM »
Thanks for the advice. I planned on using these since they are heavy ply and pretty rugged. Your idea about the rim centers is a good one. Do the 16.5 skid steer rims give that many problems with breaking a bead? Are they any different than tractor tires?
« Reply #8 on: April 05, 2020, 11:37:04 PM »
Some 16.5" wheels do indeed have the "safety bead" but not all do. Not any different than most other heavy equipment wheels. At low pressures they are more prone to knocking the beads off.
Never shopped around but here is an 8 bolt 8" bolt circle hub that should fit your wheel. Just have to double check the center hub hole dimension.
Hub Assembly, 8 Stud, 8 In. Bolt Pattern, 6000 Lb. Capacity
TJ225 hubs on a TJ208?
Started by Ironbarkloggers on Forestry and Logging
Last post June 11, 2014, 09:30:01 PM
by Ironbarkloggers
Dual tandem axle vs triple axle singles
Started by mart on General Board
Last post February 24, 2016, 11:21:39 PM
by mart
2 Golf cart 4 bolt hubs w/ bearings.
Started by Ironwood on Wanted
Last post February 05, 2006, 01:38:36 PM
by Ironwood
Need Rear Axle 540 A Have Axle Assembly 440 C And 540D
Started by lonewolf on Wanted
Last post March 17, 2009, 10:40:15 PM
by lonewolf
