Electric issue with winch on log arch
Started by Kwill, March 21, 2020, 01:40:33 PM
Kwill
I have continuity across these post. I'm thinking that would be a dead short wouldnt it?
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
btulloh
It's only going to be about 3 or 4 ohms when it's ok.  It would look like a dead short depending on how you're checking it.  You need a meter that will read low ohms (most will).
HM126
Kwill
Quote from: btulloh on March 21, 2020, 01:43:24 PM
I tested across the terminals. 1.2 ohms
What is the problem? What is happening when you connect 12VDC?
btulloh
Quote from: Kwill on March 21, 2020, 01:52:36 PM
That could be correct depending on the rated power of the motor. MM's question is the next step.
HM126
Kwill
Quote from: Magicman on March 21, 2020, 01:55:12 PM
It was making my lights come on on my tractor when I hit the switch. Like it was back feeding
donbj
What are you tied into on your tractor with your supply wires?
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Kwill
Quote from: donbj on March 21, 2020, 02:57:49 PM
Straight to the battery
Ljohnsaw
Is your tractor positive or negative ground?
John Sawicky
Ljohnsaw
Also, assuming this is with the arch attached to the tractor.  Have you tried it with it not attached? Results?
John Sawicky
Kwill
donbj
Are you fully hard wired to the battery or using the arch hitch as ground connection?
Kwill
Turns out some cobbled up wiring that had something to do with the volt meter off the negative side of the battery was causing issues. Took that off and no volt meter now but the winch works fine. Always something. Wasted somr of this nice day jacking around when I should of had a trailer full of logs
doc henderson
might have been and amp meter if it had a flat bar "shunt"  for measuring current on the negative side of the battery.
Stephen1
Quote from: Kwill on March 21, 2020, 04:42:52 PM
Always Something is right. As long as we want to use equipment, new, old, home built, it will always be something. Some days it is better than others for sure.
donbj
I'm still curious how it got the lights on but glad you're mobile.
