Author Topic: MS-310 piston scoring....  (Read 152 times)
Offline mrcaptainbob
« on: March 26, 2020, 10:45:18 PM »
Here are
 the two sides of the piston. The cylinder is the same way. Carb side smooth, exhaust side heavily scored. Both sides of the rings, including the rings.
Re: MS-310 piston scoring....
« Reply #1 on: March 26, 2020, 10:47:18 PM »
What might have caused this?
Offline sawguy21
« Reply #2 on: March 26, 2020, 10:49:31 PM »
Overheated. It was likely running too lean or insufficient oil. Could also be an intake air leak.
« Reply #3 on: March 26, 2020, 11:13:17 PM »
Hmm... don't think it was insufficient oil in the mix. I'm pretty judicious about that. It's only ever tasted Stihl mix and always at 50:1 with maybe a dribble more oil in the mix. Always.
So that leaves the lean issue or air leak. I checked the carb boot and it's air tight. Will check the other tubes and hoses and verify. I presume lung pressure is sufficient for air leak test...?
Offline sablatnic
« Reply #4 on: March 27, 2020, 02:05:58 AM »
Could be mixture, that was too old.
Offline sawguy21
« Reply #5 on: March 27, 2020, 04:23:28 AM »
A Mighty-Vac or similar tool is needed to pressure test, the pressure needs to hold.
« Reply #6 on: March 27, 2020, 09:25:45 PM »
The last couple times I used it there was evidence of a lot of 'splashing' from the muffler on the face of the wood being cut. Did not know it was blowing past the piston right out of the exhaust!
piston scoring
Started by tlbrooks on Chainsaws
Last post December 06, 2018, 08:05:49 PM
by tlbrooks
Replace piston rings, piston, or cylinder?
Started by Spruce_Goose on Chainsaws
Last post May 11, 2014, 10:28:50 PM
by Al_Smith
Scoring
Started by ramv102000 on Chainsaws
Last post November 19, 2013, 07:06:09 PM
by sharkey
WooHoo,, Scoring a Forklift !
Started by Cypressstump on Sawmills and Milling
Last post July 18, 2012, 03:44:24 PM
by Ironwood
