Some Tech Trivia Video's, Nerd Stuff. Crank Shafts & Thread Type Of things...
Started by weimedog, April 03, 2020, 11:17:04 AM
weimedog
First The Different Puller Threads Common To Pullers For Your Shop:
https://www.youtube.com/watch?v=HD8n3kiSTG4
Second A nuance with the Husqvarna 61-272 series & the two major changes with cases then THREE major changes relative to cranks, flywheels and ignitions. Two Cranks, the 10mm flywheel thread & 8mm Flywheel Thread cranks. Two ignition system configuration's, the newer single coil system and older two coil system. AND the "fly" in the ointment. Flywheels. At least three configurations...and what happens with you mix the wrong way...:)
https://www.youtube.com/watch?v=lsgrc018nWY
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
