Author Topic: White poplar for board & batten  (Read 624 times)
Offline frazman
« on: April 07, 2020, 09:36:34 PM »
I have a good number of white poplar ( trembling aspen ) logs to be used for board & batten but the boards will only be used next year so I was wondering, would it be a good idea to cut the boards this year and have them dry or should I keep the logs whole and off the ground and dry to be milled next year. From what I've read, normally you cut the board and have them nail green.
Offline Don P
    • Calculator Index
Re: White poplar for board & batten
« Reply #1 on: April 07, 2020, 10:25:29 PM »
I'm sawing some white pine now that will dry for a coupla few months, then I'll plane it all flat and uniform when its time to install.
The future is a foreign country, they will do things differently there - Simon Winchester
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: April 08, 2020, 07:51:05 AM »
Better to cut and dry the boards rather than leave the logs lay for a long time as some bad things can happen to the logs like deep cracks and splits and some rot could develop in the sapwood.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline frazman
« Reply #3 on: April 08, 2020, 09:42:35 PM »
I think I'm going to take care of milling the logs this year as suggested and cut them a little thicker @ 1-1/8" ish. This will give me good experience and what to expect for any future jobs. Thanks for all the info.
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #4 on: April 08, 2020, 10:30:38 PM »
Saw them now, dry them, use them later.  IMO it takes the risk out of the situation.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a tree.  Sawmills cut logs, trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  So donít burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline GeneWengert-WoodDoc
« Reply #5 on: April 08, 2020, 11:11:17 PM »
Poplar is so prone to blue stain, that you should saw promptly and then stack, with a roof, in a fast drying location.
Offline frazman
« Reply #6 on: April 09, 2020, 07:56:38 PM »
Looks like I'm not sawing as fast as I should being I still have to set my new sawmill. Happy the weather is still cold for some time...
« Reply #7 on: April 09, 2020, 11:02:40 PM »
Has anyone mentioned Westwood in aspen to you?  This is a bacterial infection in the tree, usually in the bottom log,  that causes an obnoxious odor, Higher than normal moisture, slow drying, and collapse.  It is very weak compared to uninflected wood.  Etc.
Offline frazman
« Reply #8 on: April 10, 2020, 07:36:14 PM »
I have cut lots of trees and found some of them to be punky in the centre of the logs if that's what you're referring to. ( ? ) Not sure what's the cause of it is.
« Reply #9 on: April 10, 2020, 08:52:25 PM »
Punky wood is from decay fungi.
Bacteria increase the moisture content.  You can often see wood that looks super wet.  The wood gets much heavier.  In some species, the logs no longer float.
Sealing Board & Batten (Poplar) question...
Started by krayzie8rt1 on General Board
Last post July 25, 2016, 06:58:03 PM
by krayzie8rt1
White Pine Board and Batten FAIL
Started by Brad_bb on Timber Framing/Log construction
Last post May 05, 2021, 09:27:48 AM
by Jstier
white pine for board and batten siding
Started by farmer mark on Timber Framing/Log construction
Last post April 03, 2014, 10:38:55 AM
by Doug_D
question
Board and Batten?
Started by Rockn H on Timber Framing/Log construction
Last post January 12, 2006, 11:38:53 AM
by Greg
