Dynamic Green Products Inc.
Author Topic: Is this poplar?  (Read 701 times)
Offline firefighter ontheside
  • I like trees.
Is this poplar?
« on: April 14, 2020, 09:47:38 AM »
I got some logs from a tree service.  The guy told me this one was poplar. I asked if it was yellow/tulip poplar and he was sure it was.  Iíve never seen it in person.  He deals with a lot of planted trees, being a tree service.  So, is this yellow poplar?  If not, what might it be.?  The one in the middle.  I know what the others are. Thanks.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
  • I like trees.
Re: Is this poplar?
« Reply #1 on: April 14, 2020, 11:15:46 AM »
I think this answers the question after I cut the end clean.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline barbender
Re: Is this poplar?
« Reply #2 on: April 14, 2020, 11:45:01 AM »
I have no yellow poplar in my area, so it's out of my realm. But that doesn't stop me from giving my opinion😁 I don't think that's poplar🤷🏽‍♂️😊
  • I like trees.
Re: Is this poplar?
« Reply #3 on: April 14, 2020, 01:01:06 PM »
I didnít think the bark looked right, but the fresh cut end looks right.  Itís green in the middle.  Iíll be milling it soon, so more pictures will follow.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline stavebuyer
Re: Is this poplar?
« Reply #4 on: April 14, 2020, 01:51:48 PM »
Not textbook typical, bark is normally a little more uniform, but the fresh cut wood favors poplar albeit open grown with that little heartwood to white wood ratio.
  • I like trees.
Re: Is this poplar?
« Reply #5 on: April 14, 2020, 03:07:01 PM »
Iíve never seen or cut fresh poplar.  This thing is super green in the heart.
Also, it has some epicormic sprouts.  Does poplar do that?
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline PoginyHill
  • Gentleman logger
Re: Is this poplar?
« Reply #6 on: April 14, 2020, 03:34:59 PM »
Definitely tulip poplar (not aspen) sometimes called yellow poplar. Although not native to my area (northern New England), the mill I work at processes it routinely. It is abundant in the mid-eastern coastal states. My only hesitation is the sap ring is much wider than what I normally see. Grain, knots, and bark are consistent with tulip.
Kubota M7060, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
Offline SwampDonkey
  • Large Tooth
Re: Is this poplar?
« Reply #7 on: April 14, 2020, 04:13:18 PM »
Them small eyes would remind me of something like a locust and might be the stipular spines that form near a lateral bud.
Move'n on.
  • I like trees.
Re: Is this poplar?
« Reply #8 on: April 14, 2020, 04:27:12 PM »
Thank all, a text sent to Danny also confirmed that it is tulip/yellow poplar.  Iím cutting it now.  Making a lot of 4/4 x 12.  Lots of knots though, so may not be making a lot of cabinets with it.  Itís really, really wet.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline barbender
Re: Is this poplar?
« Reply #9 on: April 15, 2020, 12:45:21 AM »
Well, if you've learned one thing here it's don't let someone from MN tell you whether you have yellow poplar or not😁
Offline SwampDonkey
  • Large Tooth
Re: Is this poplar?
« Reply #10 on: April 15, 2020, 05:45:07 AM »
All of our balsam poplar of any size up here has that dark middle and white wood from there to the bark. But that is a totally different genus.  Up here we would call your poplar, tulip tree, since that is what the Latin name calls it. One of them resistance to change things. :D
Move'n on.
Offline moodnacreek
  • Sawin by the notches
Re: Is this poplar?
« Reply #11 on: April 15, 2020, 08:11:29 AM »
Sure looks like tulip. Bark almost like ash. About half white wood and half green heart. Traces of violet , red or purple may be seen. Does not smell anything like aspen. Is related to magnolia. Is about the largest hardwood tree in the country.
  • I like trees.
Re: Is this poplar?
« Reply #12 on: April 15, 2020, 08:52:04 AM »
Iíve used a ton of yellow poplar to build face frames for cabinets and bookcases, but had never seen the tree.  Itís nice to cut.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
  • I like trees.
Re: Is this poplar?
« Reply #13 on: April 15, 2020, 08:53:19 AM »
Lol.  Someone from MO is no better obviously.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline Don P
    • Calculator Index
Re: Is this poplar?
« Reply #14 on: April 15, 2020, 09:08:19 AM »
Yup, its fun to cut, on the circle mill I'll often see a wave of water in front of the blade. With the demise of the chestnut it became the largest tree in the eastern forest. I've laid on stumps with room at both head and toe. It often occupies the same ground as the old chestnuts.
 The white is candy to powderpost beetles, they aren't too interested in the green heart but I borate the boards pretty quickly. It does have epicormic branch stubs just under the bark. If the bark is slipping remove some and you'll see the barbs, those things are sharp enough to take the hide off of you.
While I'm home sawing white pine for one future project my partner is home sawing poplar for the one after that. I used poplar for these windows. We have a houseful to make for that summer job.
  • I like trees.
Re: Is this poplar?
« Reply #15 on: April 15, 2020, 06:44:20 PM »
Iíve always seen little Birdseye looking figure poplar.  Now I know it was from the sprouts.  I finished milling that log today.  I got about sixteen 1x12ís.  Good to know about the ppb.  I did spray it with borate.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
(Poplar) POPLAR SAW LOGS
Started by thumper on Forestry and Logging
Last post February 21, 2010, 08:28:13 AM
by thecfarm
big poplar
Started by sandsawmill14 on Sawmills and Milling
Last post March 04, 2015, 07:46:14 AM
by sandsawmill14
Poplar log pic
Started by Jemclimber on Sawmills and Milling
Last post April 03, 2012, 09:55:50 PM
by MotorSeven
poplar
Started by downeastmark on Sawmills and Milling
Last post August 30, 2011, 08:02:53 AM
by thecfarm
