Author Topic: Woodmizer LT40/50/70 Parts, Free**  (Read 642 times)
Online terrifictimbersllc
    • Terrific Timbers LLC
« on: April 20, 2020, 03:59:28 AM »
Parts which might be of interest to someone building, or possibly repairing a sawmill.....
The diagrams I refer to, are attached as pdfs.
WM #036416. Log loading arm assembly, list $500  #1 in the loader diagram
WM #W09444 Hydraulic log loading foot channel (aka foot pad) List $130. #7 in the loader diagram
WM #015204 Super97 Frame weldment List $378.  #1 in the weldment diagram
Explanations.
These loader arms got bent when a 2900# log rolled off of the bed,  up over the arms onto the ground. They have a "twist" in them which results in the tip of one arm being about 3" higher than the other when they're on the ground.  I could demonstrate it with a photo of the arms placed on a flat surface like a floor, when I have time to do this. These came off of an almost brand new LT70Super, I didnt want to remember this event for the rest of the time I own this mill, so I just got new arms.
The foot pad has a slight bend in it which is really just cosmetic.  Same incident as above.   I didn't want to remember that either so got a new one.
The Super 97 Frame Weldment (dont ask me where this name comes from), is the one that came on the mill. It is the "frame" that the springs/axle, and mill, are attached to.  Woodmizer sent me a replacement weldment that has a 3/8" thick steel bar welded to each of the 2-1/2 x2-1/2 x approx 50" tubes that are part of this frame.  The LT70 Super weighs about 6000# and needs the reinforced version to avoid flex in these tubes.  As is, this weldment I am offering is the same one that is on an LT40Super which weighs about 4500# which has no issue with the flexing that is seen on the heavier mill.  So this weldment would be an ideal starting point for anyone wishing to have a platform to mount his/her mill on, which will also accept standard Dexter springs/axle.  I see many here building trailers for mills and IMO this would be a good way to go.
To me these are just scrap metal. I am offering them free* which means the following.  Pickup at my location in Mystic, CT.  That free has no *.    I am willing to strap them to a pallet and ship to your destination, you pay shipping and give me an extra $100 for my efforts which I will donate to the Forestry Forum.  I would expect the freight cost will be somewhere $150-$250.  I can get the weights for you if you want to get an estimate.
Happy to answer any questions.
I have read the Forestry Forum conditions for posting in this section and agree to them.
Re: Woodmizer LT40/50/70 Parts, Free**
« Reply #1 on: April 23, 2020, 02:13:53 PM »
I have a taker for the loader arms and foot pad.  He'll provide a $60 check to FF.
That leaves the frame weldment, ideal for a DIY mill builder who can pay the remaining $40 to FF plus take care of its freight.
Update 4/24.....
Here is the loader and foot ready to ship.  Truck is picking it up in 30 minutes. I'll load it for him.
@spearstj  4/24/2020 12:45pm,  It's on its way to you.  Happy loading!
Offline Spearstj
« Reply #2 on: April 23, 2020, 03:45:22 PM »
Confirmed, I will take the loader parts.  Thx for helping out a fellow sawyer make a well needed upgrade to a non-hydraulic LT30.  Now I just need to get the log clamp and turner going, lots of ideas on this forum that I should be able to incorporate.
Thx TerrificTimbersLLC!
« Reply #3 on: April 24, 2020, 01:44:28 PM »
Here are some pictures showing the frame weldment and its removal.  I think the weldment  weighs about 80 pounds.
Picture below: Bolts at either end holding springs are removed, springs and axle lowered to ground.  The weldment is the black thing attached to the underside of the sawmill.
Below.  Now 4 bolts holding the weldment to the underside of the mill are removed, and the weldment is now on the ground.  The bolts can be seen hanging from the mill.  They previously were through the holes in the weldment cross tubes.
Below.  Now the weldment is pulled out on the pavement on the loader side of the mill (this mill does not have its loader arms on at this point).
The schematic showing the weldment and axle parts is attached as a pdf in the first post above.  This weldment part forms a good method for attaching the sawmill to an axle and springs.
It is available to someone who wants to either pick it up in Mystic CT, or cover shipping to his location, for a contribution of $40 to the Forestry Forum.
Offline Spearstj
« Reply #4 on: April 29, 2020, 11:49:10 AM »
Just arrived, now I have my work cut out for me to get this fitted up to the old LT30!
THx Dennis!
P.S. I like orange sawmills but I prefer green tractors!  No offense Dennis, just noticed the color of those loader forks in your posts and figured I would rib ya some!  Thx again for the loader arms!
« Reply #5 on: April 29, 2020, 04:59:12 PM »
None taken. Glad to help anyone/anything FF or orange.  That tractor is green, yes, it is a common emotional reaction for many tractors when picking up a pallet that was last handled by a Kubota.  :D  :D
Offline Spearstj
« Reply #6 on: April 29, 2020, 07:58:10 PM »
Touche  my friend, touche!   :)
Want to help someone.. free Genuine Franklin Parts
Started by bkellyvtme on Forestry and Logging
Last post May 31, 2014, 06:51:35 PM
by ozarkgem
Woodmizer Setworks for parts
Started by PAmizerman on For Sale
Last post February 07, 2020, 08:16:58 PM
by PAmizerman
Woodmizer simple setworks used parts
Started by ftwjr on Wanted
Last post March 28, 2011, 09:06:02 PM
by ftwjr
Woodmizer Accuset one parts. SOLD
Started by ShowMeSawyer on For Sale
Last post July 14, 2018, 10:41:14 PM
by stihltoomany
