Dynamic Green Products Inc.
Author Topic: Stihl Chain Saw 310 will not shut off.  (Read 399 times)
Offline reevesjo
« on: April 22, 2020, 03:50:26 PM »
That's right.  Most problems are chain saws wont start.  The kill wire seems to be contacting the off switch OK.  I even tried to ground the switch with the kill wire with a screw driver.  No luck stopping the saw.  Need to know where the kill wire goes to before I start disassembling the saw.  Or, any other suggestions.  I finally got the saw stopped by flipping the spark plug wire.  This is a little unhandy.
Offline Air Lad
  • Wood is good
Re: Stihl Chain Saw 310 will not shut off.
« Reply #1 on: April 22, 2020, 06:49:36 PM »
Hey Jo
In the short term you can just use choke to stop
Kill switch circuit goes from the body of the coil to
the switch and then to ground somewhere on the engine body
If the switch has gone open circuit that would fail to stop the engine
If a wire has come adrift , that will fail to stop the engine
 You have got this  smiley_thumbsup
Offline reevesjo
« Reply #2 on: April 22, 2020, 09:30:52 PM »
Thanks Air Lad,
Can't set the choke on this 310 without pulling the throttle trigger wide open.  However that works.  I dug a little deeper and found broken kill wire at the coil.  Not as difficult as I thought.  Only required removing 4 Torx socket screws and removing the recoil start cover.  Case closed!!
Oregon Chain Grinder vs. Stihl chain angles
Started by Chelsea Tree on Chainsaws
Last post July 08, 2013, 07:58:36 AM
by bandmiller2
Stihl 3/8 MM3 chain = Pico Chain? (MS170)
Started by Old Greenhorn on Chainsaws
Last post October 07, 2020, 03:12:12 PM
by Hickory Bow
Where to buy Stihl RM chain?
Started by MNBobcat on Chainsaws
Last post November 08, 2018, 06:25:10 PM
by thecfarm
Stihl MS 361 bar and chain
Started by Lyndaker on Chainsaws
Last post January 17, 2019, 09:53:25 PM
by Inaotherlife
