Talon 38cc- pooling bar oil. Adjustment screw or bigger issue?
I have trying to get this chainsaw starting and running properly. I seem to have that sorted .
However , I took the bar off in order to safely run the saw and make idle and L / H adjustments. Whilst I have been running and adjusting the carbs, It is then that I noticed at least 10 +mls of oil pooling under the unit. It clean oil and Im sure coming from the bar.
Is this normal? Is there an adjustment screw for this?
