Dynamic Green Products Inc.
Author Topic: Persimmon saplings??  (Read 662 times)
Offline Watrboyo1
« on: April 26, 2020, 03:36:50 PM »
Can someone tell me if this is a persimmon sapling and if so what would be the best way to transplant this(stump bucket) and when would be the best time also it will be transplanted on the same property just a few hundred yards away
Live for the outdoors
Offline Watrboyo1
Re: Persimmon saplings??
« Reply #1 on: April 26, 2020, 03:49:53 PM »
Offline Poquo
« Reply #2 on: April 28, 2020, 06:41:38 AM »
Yes it looks like Persimmon , I find them in my yard a lot . I dig them up carefully trying not to damage the roots , replant in new location make sure to keep watered for several days . I pick out the smallest saplings to move its a lot easier to dig them up.
2015 Woodmizer LT40HD26
Offline kantuckid
« Reply #3 on: April 30, 2020, 09:51:13 AM »
Couple years back a KY state U professor did a project on persimmons and pawpaws. He sought the best tasting, most productive, etc. trees for seeds to work with toward a commercial use. I don't know where it all ended but something to look into.
There a nursery in KY that deals in such stuff plus hardy pecans, heartnut trees, etc. I think the name is "Englands Nursery"?
Honestly most persimmons I've picked up were about the same-if ripe. I pulp them in a food mill like maters then freeze for cookies & breads. very tasty! pawpaws I don't like and most get eaten before I see them anyway.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #4 on: April 30, 2020, 06:34:58 PM »
Good luck getting enough roots with them to transplant. I tried to move several from N. Fla to WV a few years back and using a shovel I never got enough root stock for them to be viable.
Offline Poquo
« Reply #5 on: May 01, 2020, 09:39:04 PM »
I collect the seeds in the fall , plant them in the spring and most of them sprout . I put a rat wire cage around where I plant to keep critters from digging them up .
 This is the best shovel I've found for digging up small trees to transplant .
Offline Watrboyo1
« Reply #6 on: May 03, 2020, 09:42:17 PM »
thanks bud, yeah I have a ton, ton, ton of pawpaws on my property, Ive found you have a bout 2 days to find them edible, and then its okay.  I haven't tried any of the local persimmons.
Offline Watrboyo1
« Reply #7 on: May 03, 2020, 09:44:06 PM »
I plan to use a stump bucket, and I'm just transplanting them to other food plots on the same property, I guess I could also try and graft some this winter.  we'll see.  but I feel if I dig a hole with stump bucket and up root tree and take straight to the hole I already dug, that I should be good, but I know they are tough to transplant
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #8 on: May 04, 2020, 08:24:59 AM »
Persimmon is dioecious, that is, there are male and female plants.  If you want persimmons, hopefully you pick a girl and not a boy :).  Transplanting is best done in the dormant season (winter) when there is less shock to the plant.
Offline Watrboyo1
« Reply #9 on: May 04, 2020, 09:22:48 AM »
I knew there were male n female. And I planned to wait til next Jan to transplant. Is there a.way to tell difference between male and female
Offline DPatton
    • D & S Sawmill Services
« Reply #10 on: May 14, 2020, 09:04:52 PM »
Yes, you have to turn them over and look under the roots!😂😂😂
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
« Reply #11 on: May 14, 2020, 09:48:52 PM »
   Just say something. If it agrees with you it is male. If it corrects you .... :D
My newest saplings
Started by Elevendy on Tree, Plant and Wood I.D.
Last post November 29, 2008, 02:40:47 PM
by RynSmith
Shipping saplings
Started by metalspinner on Ask The Forester
Last post February 03, 2011, 11:45:42 AM
by SwampDonkey
question
Best place to buy saplings?
Started by jcampbell300 on Forestry and Logging
Last post September 24, 2020, 08:21:23 AM
by kantuckid
Transplanting oak saplings
Started by wesdor on Ask The Forester
Last post May 02, 2005, 10:57:56 AM
by populus
