Dynamic Green Products Inc.
Author Topic: 63 Timberland and Ellicott 205 skidder resto mod  (Read 2581 times)
Offline bushmechanic
  • Someone else has it worse than you.
Re: 63 Timberland and Ellicott 205 skidder resto mod
« Reply #20 on: July 26, 2020, 06:52:29 PM »
Took some pic's for you this evening. Some are clutch applied and some released also some of the linkages. Sorry for the long reply but I've been in the bush and out of cell service.
The clutch is an over center design ( snap clutch ) center in for application and out for release. Is that air cylinders you have on that for controls? Looks like a good idea to control from the cab. Hope this helps.
Offline Dwood01
  • Hey
« Reply #21 on: July 28, 2020, 12:04:51 AM »
It had a fordson 4cyl diesel it now has a hino 175hp 4cyl diesel
How is that Hino motor to work on and run?
Case 825 Skid King With Backhoe Attachment
1991 Ford F250
Offline Aussie.shane
« Reply #22 on: July 30, 2020, 07:24:02 PM »
Thanks bush mechanic looks like I have mine set up right just having issues setting the tension to freespool and not slip . Yes I have the winch on/off and freespool on air cylinders as I kept the air system from the doner truck with a smaller tank fitted under the winch makes operation of the winch a lot more user friendly from inside the cab
« Reply #23 on: July 30, 2020, 07:26:45 PM »
So far it has been faultless starts easy plenty of low down power and parts are plentiful here in Australia
Want to buy some timberland?
Started by Faron on General Board
Last post September 19, 2008, 10:49:02 AM
by SwampDonkey
Canadian Timberland?
Started by luke on Forestry and Logging
Last post June 23, 2004, 04:41:33 PM
by leweee
Buying Timberland between 50 to 100 acres
Started by dmgage on General Board
Last post October 14, 2012, 06:02:01 AM
by Kansas
question
buying timberland for conservation and logging?
Started by MyWorkingForest on Ask The Forester
Last post September 25, 2012, 07:00:10 AM
by Dobie
