Author Topic: 22 hp Predator photo  (Read 771 times)
Offline ktm250rider
« on: May 10, 2020, 04:05:43 PM »
Anyone with a 22hp predator engine that could take a photo for me?  Im looking for a photo of the springs and linkages just behind the muffler.  I have two springs connected to each other and Im not sure why or if I screwed something up converting to remote throttle.
Offline VooDooChikin04
Re: 22 hp Predator photo
« Reply #1 on: May 10, 2020, 04:28:17 PM »
hope this helps. its the best I could find.
Offline ktm250rider
« Reply #2 on: May 11, 2020, 07:17:47 AM »
yes, kinda-sorta.  Do you happen to have anything showing the linkage perpendicular to the springs in the first picture?  On the right side of the engine as you looking at it in the photo.
Mine looks a bit different for some reason too.
« Reply #3 on: May 11, 2020, 08:15:41 AM »
Sorry, those are the only photos I could get. It seems like the two springs connection to a stationary arm on the left, and then each spring hooks to a separate linkage on the right. Post your setup and I can help.
Offline ktm250rider
« Reply #4 on: May 11, 2020, 09:39:51 AM »
thanks, ill get a picture tonight if its not raining when I get home.  I think the spring im thinking of is actually removed when a remote throttle is added.
Offline Dkelley1981
  • Member*
« Reply #5 on: June 19, 2020, 06:51:38 PM »
Did you ever find what you were looking for? I just made first cut on old lumbermate 2000 with a fresh predator engine. Like brand new again.
Photo Resizer for posting photo's if your having trouble with Javauploader
Started by Piston on General Board
Last post June 21, 2010, 06:38:57 PM
by Piston
Predator
Started by garyfg on Sawmills and Milling
Last post November 11, 2015, 10:46:06 PM
by Kingmt
sad
Predator 420
Started by MikeZ on Sawmills and Milling
Last post January 01, 2016, 06:37:32 AM
by Kbeitz
Predator Challenge 2005
Started by pasbuild on The Outdoor Board
Last post February 04, 2005, 08:00:53 PM
by jtmccallum
