such a small angle, you can play with the idea of cutting the splay angle for the legs, on the backside of the aprons. just run it through the table saw, and have the legs splay out, and skip the half lab on the leg. The outside is square but the inside has the 2.5° angle. or with leg taper on the inside 2 sides, the leg will look splayed but is really perpendicular. making it look more refined. I have called my stuff elegant rustic. bark on one side, but a kid cannot scrape or cut themselves easily. sounds like a traditional wood worker problem. so much wood with so many ideas, and so little time, and never enough tools.
Started by LeeB on Technical Support Topics
Started by arnold113 on Sawmills and Milling
Started by JoeyLowe on Sawmills and Milling
Started by rasawing on Chainsaws
