We have contest winners!
Yeah the only real difference would be that it's in a saw compared to what I've used it for in the past, mainly on large bearing fits in industrial motors, gearboxes, etc. In the steel mill environment. The RPM's would definitely be higher.
I would metal shim AND Loctite both. I've done this over a decade ago with no failures on a working saw. I can't even remember the saw model now, but it was a larger Husky.Nothing proprietary about chainsaws over other machinery except being mindful about the max rpm's and constant exposure to gas/oil.Kevin
Quote from: Real1shepherd on May 17, 2020, 05:42:41 PMI would metal shim AND Loctite both. I've done this over a decade ago with no failures on a working saw. I can't even remember the saw model now, but it was a larger Husky.Nothing proprietary about chainsaws over other machinery except being mindful about the max rpm's and constant exposure to gas/oil.KevinWhat material for the shim Kevin?Also how about Devcon to fill the worn bearing housing?
Started by GRP7099 on Wanted
Started by Chuck White on Sawmills and Milling
Started by Waterford Woodworks on Sawmills and Milling
Started by weimedog on Chainsaws
