Author Topic: Cooks Sharpener VS Dinasaw  (Read 1098 times)
Offline rick42wood
« on: May 22, 2020, 06:23:32 PM »
I am researching Sharpeners and Setters and have narrowed the selection to either Cooks or Dinasaw.  Both seem to be well built compared to most others but the price reflects it. It seems though that the Cooks requires more stuff to be purchased to cover different blade brands where the Dinasaw can just be adjusted for various blades.  Having to buy a different cam for a different blade brand would seem to preclude sharpening other peoples blades as a side line.  Would like to hear opinions from anyone using either.
Old guy, Still learning
Offline Bruno of NH
Re: Cooks Sharpener VS Dinasaw
« Reply #1 on: May 22, 2020, 07:58:50 PM »
I'm looking into a sharpener and setter.
The Dinasaw look interesting to me.
I have reached out to 2 places that sell them and no one has got back to me.
I was wondering if it ran without cams.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline hamish
« Reply #2 on: May 22, 2020, 08:16:37 PM »
I have the Dinasaw sharpener and setter, quality is out standing as is the performance.  It takes a lil to understand how to set it up and adjust.  Consider it like buying a Mercedes vs a Kia.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Online Brian_Rhoad
« Reply #3 on: May 22, 2020, 09:17:17 PM »
I have 2 Dinasaw sharpeners. I haven't found a blade I can't sharpen with the adjustments. They do take some time to figure out but I like how they work.
Offline Bruno of NH
« Reply #4 on: May 22, 2020, 11:43:57 PM »
Is the grind wheel on the Dina saw a dry cbn ?
Online Brian_Rhoad
« Reply #5 on: May 23, 2020, 12:31:24 AM »
I think you can get a CBN wheel for it. I like the bonded wheels. I shape the wheel to fine tune the sharpening.
Offline Bruno of NH
« Reply #6 on: May 23, 2020, 07:12:58 AM »
Could you guys with the Dina saw point me to a place I could buy one?
Do you have the fully auto or hand crank ?
Online Brian_Rhoad
« Reply #7 on: May 23, 2020, 11:26:15 AM »
I have one of each. They are the older models.
Bailey's sells them.  Bailey's
Offline rick42wood
« Reply #8 on: May 23, 2020, 01:25:17 PM »
The Dinasaw Australian web site has a link to find distributors.
Online farmfromkansas
« Reply #9 on: May 23, 2020, 06:06:30 PM »
You guys need to get Tom the Sawyer to add his comment to this post.  He has a Timberking sharpener, and says it is adjustable.  Less expensive than either of the others discussed.
Offline uler3161
« Reply #10 on: May 23, 2020, 08:29:12 PM »
Dinasaw sharpener owner here. I think we bought it maybe 13 or 14 years ago. It is a very versatile machine due to the adjustments as well as the bevel grind. However, it requires a lot of patience to learn. If you get one, prepare to spend some time getting familiar with the controls.
Never saw the Cooks in person, but the photos suggest it's better built. The Dinasaw is a little lightweight in my opinion. Some of the gears are made of a plastic material, though we never had any issues with that. We did have a part that you might call the cam get wore down. Ordered a new one through Baileys and it was a different cam. Sent it back and Baileys machined it for us. Very very very happy with Baileys for doing that, but it did kind of seem kinda odd that it was a different design.
On grinding stones, it does seem to have an odd arbor size. Don't remember off the top of my head what it is, but the selection of stones for that arbor wasn't great last time I ordered some. Dad used to do all the grinding and his opinion was that while the cyclone wheels are nice, they don't last long enough to warrant the purchase over regular stone.
I actually have one of their setters, but never used it. We were kind of particular about setting. And after setting for 20+ years with a single tooth setter with dial indicator, we really weren't convinced their design was that great. There's just too much variation in teeth (even in the same blade). Some teeth bend over like they are lead, some bend back like spring steel. And quite often you have to bend teeth back the other way, which that setter didn't do and there's no way to tell that you need to.
1989 LT40HD, 12ft extension, WoodMaster 718, Fordson Major Diesel, Champ CB40 Forklift
Dan
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #11 on: May 23, 2020, 11:19:48 PM »
OP set the match up in this one, I haven't used either of those... no dog in this fight.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Offline Hilltop366
« Reply #12 on: May 24, 2020, 12:05:07 PM »
rick42wood, wondering if you have ever seen this one? I have no idea how well it works but I thought it was interesting. It made and sold in Canada, would be handy not to pay exchange and duty.
https://www.vieltools.com/produit/affuteuse-de-lame-de-scie-a-ruban-viel-apex-rf-1504
« Reply #13 on: May 24, 2020, 01:10:19 PM »
Interesting video, too bad they don't speak English.
Offline rick42wood
« Reply #14 on: May 24, 2020, 01:59:32 PM »
I cant place it just now but I have seen this same machine under a different name.  I dont like the idea of having to buy an expensive wheel for each different blade.  It kinds of precludes sharpening other peoples blades as a sideline.
BTW, caution required using CooksCanada web site.  The prices displayed are in US dollars but it is not evident until you go to check out.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #15 on: May 24, 2020, 02:33:01 PM »
The cost up front for CBN wheels is more than other type grinding wheels/rocks.  The longevity is greater.  In the end the difference in  cost per blade for abrasives pennies.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Unclefish
« Reply #16 on: May 24, 2020, 06:23:40 PM »
So if you where  going to spend 2300 on Dinasaw why not just buy the woodmizer BMS250 for 1800 which I have only heard how good it is. I am in same boat right now looking for a sharpener. I HAVEN'T pulled the trigger on anything yet. I have about 50 blades sitting to be sharpened. But I don't go through alot in a year. Being a hobby sawer. I would buy the manual machine but my shoulders are shot from being a Diesel mechanic and I think that repeative motion would destroy them even more.
Offline Bruno of NH
« Reply #17 on: May 24, 2020, 07:22:34 PM »
The Woodmizer uses oil and a cbn wheel for each profile.
They do a supper job.
But I like the Dinasaw because it uses the same wheel.
That's why I'm looking in to that.
I use different profiles for what I'm cutting and the season I'm cutting it in.
Offline Stephen1
    • muskoka Sawmill
« Reply #18 on: May 24, 2020, 08:20:12 PM »
After going through the old drag sharpener with a grinding stone that needs shaping, I would quite sawing if I had to go through all the trouble again of shaping wheels,  It needed different cams fo different profiles, I would go through 3-4 stones in a year. That alone was over $250 for stones + tax and shipping. CBN wheel $200 incuding Tax and shipping.
I would only buy a unit with a CBN grinding wheel. I am still on the same 7/39Turbo wheel after 18 months of sharpening, at least 100 sharpenings with it and still going strong.  Hands down the simplesest and best sharpening wheel out there.  I do not find the oil a major problem. I will probably switch to mineral oil next winter. I have 4 profiles and mainly am using 7/39 Turbo now. I can sharpen a 10-7-and the 7turbo and a diamond blade for the carbide blades.  and lately only been sawing with the 7turbo. I might upgrade to the 7/47 but 7/39 is working on everything I have sawn this year.
I sharpen and set a few 10's for a neighbour and another sawyer has switched to 7T so I can sharpen his blades.
Online barbender
« Reply #19 on: May 25, 2020, 01:15:05 AM »
I went the direction I did (Cook's Catclaw) because I wanted the versatility to be able to switch cams if I wanted to sharpen for others. After about 8-10 years, I've sharpened about 40 blades for a coworker, and just used the cam that came on the machine. I'm really not interested in sharpening for others at this point, I just want sharp blades for myself. My advice would be to go CBN, I think guys are getting better results in less time with CBN. You'll probably settle on 3 blade profiles at the most, just buy a wheel for each one.
Cooks and Dinasaw sharpener
Started by jclvsall on For Sale
Last post November 05, 2015, 06:56:23 PM
by jclvsall
Dinasaw sharpener
Started by Neil_B on Sawmills and Milling
Last post December 12, 2003, 07:23:21 PM
by Neil_B
Dinasaw sharpener
Started by coastlogger on Sawmills and Milling
Last post October 19, 2013, 09:36:56 PM
by ND rancher
dinasaw sharpener voltage question
Last post February 14, 2014, 10:34:22 AM
by Brian_Rhoad
