Author Topic: WM guide roller question  (Read 282 times)
Offline armechanic
« on: May 27, 2020, 08:59:15 AM »
How is the best way to do the 1/4" deflection measurement ?  My mill has been setting for some time due to medical issues, now I am trying to get it back running.  New battery, up & down motor bad. The mill is mostly original with less than 600 hrs. New gas clean carb. lube.  It is !989 LT40HD. I have tractors w/forks to move things, but it will be a learning time, Broke back, crushed shoulder and one lung.  I don't ride mules anymore !
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: WM guide roller question
« Reply #1 on: May 27, 2020, 09:20:25 AM »
Best to use new belts, and have a clean blade.
1) Raise the rollers or take them off, so they do not contact the blade.  Measure the height of the blade nearest either side.  Should be the same, or the outside 1/16" higher than the inside.
2) Now put the rollers back in, and adjust them so that they push the blade down 1/4" from the above measurements.  That's all.
However there are more steps than this in a complete alignment. You may wish to do that procedure as well, which involves making sure:
- that each bunk is the same distance from the blade (without the rollers as in step 1 above)
- that the blade tracks properly on both wheels under tension
-the guide arm moves in and out straight both vertically and horizontally
-there is 1/4" down pressure
-flange at back of the rollers are correct distance from back of blade
-each roller holds the blade parallel to the bunks
-finally tilting the head slightly so outside is 1/16" higher than inside
-adjusting the uprights to 90 degrees and adjusting them and any other small stops to be in a straight line
Should get the complete alignment procedure for your mill from WM if you don't have it.   Good luck.
Offline armechanic
« Reply #2 on: May 27, 2020, 07:15:15 PM »
Thanks for reply.  I had an idea that I would need to get the rollers up off the blade.  My manual don't show the procedure and sometimes I can't see the forest for the trees.
guide roller bearing question
Started by limbrat on Sawmills and Milling
Last post February 01, 2011, 11:11:17 AM
by ely
Roller guide adjustment question
Started by Jhoff on Sawmills and Milling
Last post April 07, 2018, 08:33:44 PM
by rrleesb
LT40 Blade guide roller question
Started by CalebL on Sawmills and Milling
Last post February 18, 2012, 11:37:10 AM
by eastberkshirecustoms
Roller guide dimensions?
Started by Celeriac on Sawmills and Milling
Last post December 10, 2011, 02:36:41 PM
by j rock
