BLUECREEPER Poster Award #4!
Had the exact same issue on my 35, turned out to be the lower cam follower. I did replace all of them at the same time.
I had the same problem to a T. Checked the lower cam follower bearing and they looked OK. However, one was decidedly warm to the touch. Lubed them with ATF and the problem went away. I routinely now squirt a squirt of ATF on the lower cam follower bearings before doing a lot of sawing.
Quote from: WDH on May 26, 2020, 06:33:33 AMI had the same problem to a T. Checked the lower cam follower bearing and they looked OK. However, one was decidedly warm to the touch. Lubed them with ATF and the problem went away. I routinely now squirt a squirt of ATF on the lower cam follower bearings before doing a lot of sawing. I stand corrected . Today mill would go forward but not in reverse. Would start back about 2 inches and seem to bind and then it would stop and not move at all. I could push the head back manually. Thought that it had to be the cam follower bearings. Called Woodmizer Tech Support and Tech said not so. Said that if it was the cam follower bearings, the problem would occur in both forward and reverse, and that it would likely trip the breaker due to high amps at motor. He said that he thought that it must be the drum switch fingers not making good contact in reverse. Told me to gently bend the fingers down to make sure that there was good contact and to apply some dielectric grease to the fingers and contact strip. Did that and problem was resolved.
This is an LT25 all manual. So no feed nor seat.I have replaced the lower cam followers several times. The last ones I bought were (supposedly) rated for 8000 pounds. Paid extra for them. I will swap them out (again) find out today if that was the issue. I have changed them at three times since I purchased the mill in 2013. I doubt if I am getting two years from the lower bearings.
Quote from: AnthonyW on May 27, 2020, 07:11:38 AMThis is an LT25 all manual. So no feed nor seat.I have replaced the lower cam followers several times. The last ones I bought were (supposedly) rated for 8000 pounds. Paid extra for them. I will swap them out (again) find out today if that was the issue. I have changed them at three times since I purchased the mill in 2013. I doubt if I am getting two years from the lower bearings.Did you use OEM? just wondering
Good luck in the change out. Keep the head secured.
Quote from: Stephen1 on May 28, 2020, 05:29:57 PMGood luck in the change out. Keep the head secured. I have swapping the lower bearings out down pat. I did the lowers yesterday at the saw site. 20 minutes tops. Ihave done either of the tops yet.
Quote from: AnthonyW on May 28, 2020, 05:31:58 PMQuote from: Stephen1 on May 28, 2020, 05:29:57 PMGood luck in the change out. Keep the head secured. I have swapping the lower bearings out down pat. I did the lowers yesterday at the saw site. 20 minutes tops. Ihave done either of the tops yet.Did it take care of the sticky spot?
Started by AnthonyW on Sawmills and Milling
Started by Dan_Shade on Sawmills and Milling
