Author Topic: Block and Tackle Recommendations  (Read 1683 times)
Offline Joe Hillmann
Re: Block and Tackle Recommendations
« Reply #20 on: July 05, 2021, 11:49:59 AM »
I have a bunch of 15,000 snatch blocks.  I double them up side by side on a clevis for top and bottom blocks when I need a block and tackle.
I think they were about $20 each and I use them as snatch blocks all the time in the woods so using them as a block and tackle just made sense rather than buying something more expensive with much less capacity.
If I wanted to use them as block and tackles all the time I would probably replace the central pins that the pulley spins on with a longer one that goes through both blocks at once.
Pulling Stumps with Block and Tackle
Started by landrand on Forestry and Logging
Last post March 07, 2006, 04:58:14 AM
by JimBuis
A Capstan, a tackle block, and a prayer
Started by Aeneas61 on Timber Framing/Log construction
Last post January 11, 2015, 08:31:27 PM
by S.Hyland
block and tackle capacity stump pulling
Started by brcisna on General Board
Last post May 02, 2016, 05:02:03 AM
by Al_Smith
Rope/chain and pulleys, block & tackle, or winch
Started by rick carpenter on General Board
Last post March 14, 2016, 08:09:41 PM
by Brucer
