Dynamic Green Products Inc.
Author Topic: Return of the Husqvarna 562XP  (Read 2300 times)
Offline Sprinter
Re: Return of the Husqvarna 562XP
« Reply #20 on: June 22, 2020, 10:58:59 AM »
Trying something new (I think). Introducing a bit of cooler air into the carb. Lifted the rear edge of the gray insert in the top cover. Ended up with a 0.25" x 1.25" slot aft of the air cleaner.
I really like the idea of cooler intake air.
Haven't tried it much yet but so far the filter seems okay.
As for aluminum tape, heat shield need an air space between the source and the target to work.
Offline HolmenTree
« Reply #21 on: June 22, 2020, 11:48:08 PM »
There's that black insert in the top cover over the airbox that already has premade  holes underneath.
Some kind of design feature that never developed or maybe a future development.  ???
Offline Wood Shed
  • Retired antique tractor guy enjoying my Tree Farm
« Reply #22 on: June 23, 2020, 10:08:38 AM »
HolmenTree,
Been following your mods for your 562xp as I have the same vintage saw.  Just recently found out that Husqvarna upgraded their new 562 models when I visited my local dealer.  Going to add the air vent holes.  I appreciate your experience and willingness to experiment while passing your knowledge.   Be safe in this heat.  I too do not shy away from running my saws when it is warm out.  My uncle always said summer time is when you cut firewood, winter is when you burn firewood.
A society grows great when old men plant trees whose shade they know they shall never sit in. -Greek Proverb
Offline Sprinter
« Reply #23 on: June 23, 2020, 01:00:28 PM »
There's that black insert in the top cover over the airbox that already has premade  holes underneath. Some kind of design feature that never developed or maybe a future development.
Maybe, they had something similar in mind.
This could easily go much further and adding screening should be no problem if necessary.
I wish I had the software to  see current temp readings. My max. temp. was 47C/117F.
Offline lxskllr
  • dummy with saw
« Reply #24 on: June 23, 2020, 06:48:05 PM »
"summer time is when you cut firewood, winter is when you burn firewood. "
I can't support that. Winter's when you cut next winter's firewood  :^D
I try not to run saws in hot weather. I do what I have to do, but my preference is to wait til it's cool. I'm happier, and the machines are happier.
Offline HolmenTree
« Reply #25 on: June 23, 2020, 07:01:37 PM »
Raised on a farm we cut and skid wood in winter on ice and let it dry in the  warmer months.
Warmer months were for field work and haying.
Offline Woodfarmer
« Reply #26 on: June 24, 2020, 09:30:40 PM »
Are the brand new 562s now pretty much bulletproof?
Offline Sprinter
« Reply #27 on: July 03, 2020, 05:38:14 PM »
My notion of opening a vent in the carb cover turned out to be bogus! It actually vents a considerable amount of air and possibly reducing potential boost pressure. So it could be a very bad thing.  :embarassed:
Offline HolmenTree
« Reply #28 on: July 08, 2020, 09:08:28 AM »
Yes that would pretty well disable the air injection flow from the rewind housing.
But then again when the cold weather plug in the airbox partition wall is removed to get cylinder heat to the carb....the saw runs fine.
Offline Woodfarmer
« Reply #29 on: August 11, 2020, 09:20:55 AM »
There is a good thread going on OPE about hot starts. One fellow added a small air deflector to clutch side as his belief is the heat transfer from the handle to the tank is causing boiling fuel. Im going to put some gasket material between the bottom handle screws and the tank to see if that helps.
I bought a newer top cover so I have one for warm weather and one for winter.
Now as for the carb deflector, I have heated handles and the wires come out right in front of the carb so there is not much room for a deflector.
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
« Reply #30 on: August 14, 2020, 08:56:59 AM »
Cut the covers on those for years now. Also cut a hole thru the baffle in the muffler right in front of the exhaust port along with a little "pipe" added up and to the clutch side, but with that tube back far enough when the saw is "rotated" into the wood it doesn't hit that pipe. Combination of a popup, muffler mod, and cut covers they start easier ( more compression ), run cooler and I never had hot start issues with those saws I did back then..( 2015-16 ) Still don't when I run them now. Did a bunch for local loggers and they never had issues and they are still out there.
1) Great little saw that had both teething issues early on ( cases/ covers/ pistons/ carbs evolved to a better place now ) but Husqvarna as a company worked through them and gave options to the point I can take the earliest and for reasonable money turn them into useful saws ( cases, cut covers, muffler mods, CST firmware updates ), almost as good as the post 2016 offerings. AND with CST along with the ability to track the parameters and update, dealers have a great tool to support those saws with that feature.
2) With out exception new technologies take time to mature.....and why the 550 MK2 and 572 are rather spectacular as new product offerings.
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
husqvarna 562xp
Started by NovaSS on Chainsaws
Last post July 05, 2014, 06:17:47 PM
by Oliver1655
Husqvarna 562xp Piston
Started by terpjr on Chainsaws
Last post October 04, 2019, 08:36:36 AM
by Pine Ridge
Husqvarna 562xp question
Started by motohed on Chainsaws
Last post April 14, 2012, 07:29:17 PM
by rocket75
Husqvarna 562xp engine burn up
Started by Beres on Chainsaws
Last post February 19, 2015, 07:02:43 PM
by Andyshine77
