Author Topic: Never used Barn find Timberking 1220  (Read 4286 times)
Offline sam-tip
Re: Never used Barn find Timberking 1220
« Reply #60 on: June 24, 2020, 10:49:48 AM »
TK manual does say check the blade alignment while on the tracks.  Good instruction on what to do in pdf of manual manual. Also watched a bunch of cooks saw videos. Figured take my time and get the blade and guide roller perfect. Did order new cooks guide rollers. Will need to weld them onto the mill when they get here.
Had to use a shaft spacer for the predator motor. 1 inch shaft to 1-1/8 shaft adapter. The mounting holes lined up just right for mounting the engine.
Central Boiler E3200 WiFi
Many many ported chainsaws. 201 to 3120
TM log splitter pro30 6 way head
D&L 1020 swing blade sawmill for slabbing
Timberking 1220
Offline Durf700
« Reply #61 on: June 24, 2020, 11:14:02 AM »
thats great progress!  update us on the next stage!
Offline Banjo picker
« Reply #62 on: June 24, 2020, 11:28:47 AM »
Maybe it should go without saying, but also check your motor alignment with your drive pulley, I have in my hasty to get something going got it “looking pretty good” and not bothering to put a straight edge across them.  That makes for excessive vibrations and belts coming off and prematurely wearing out. Hope it goes well with you.  Banjo
Offline sam-tip
« Reply #63 on: June 28, 2020, 08:05:10 PM »
The mill is cutting wood.
First log.  Nice white oak.  Just a little iron in the log.  But missed it.
Finishing the last side of the cant.
Timberking 1220
« Reply #64 on: June 28, 2020, 08:11:10 PM »
Looks like you got a winner there, and a great deal to boot.  Banjo
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #65 on: June 29, 2020, 11:33:23 AM »
YEA!!!! 8)
Good for you! You must feel really good about this project now.
Offline Durf700
« Reply #66 on: June 29, 2020, 10:23:06 PM »
great job on getting that mill running and cutting again!  i'm sure the mill is much happier also!
Offline Southside
    • White Oak Meadows
« Reply #67 on: June 29, 2020, 11:02:59 PM »
Great job!!!  You might want to check the tension on your drive belt.  Maybe it's just the camera but it sure seemed to have a lot of fluctuation in it and that will negatively impact band speed, which will affect cut quality.  It's a regular maintenance thing, usually in the 50 hour range.
White Oak Meadows
Offline thecfarm
« Reply #68 on: June 30, 2020, 05:32:09 AM »
Good for you!!
Offline doc henderson
« Reply #69 on: June 30, 2020, 06:54:59 AM »
TK has a tool for proper drive belt tension.  It does that on the slack side of the drive belt, and some is normal.  it is a spring loaded telescoping force meter.  the belts are heavy duty double wide.
Offline sam-tip
« Reply #70 on: June 30, 2020, 09:27:50 AM »
Don't forget this this is a 2007 model of the 1220.  It does not have a spring loaded belt tensioner.  Just the position of the motor.  I do think it could use a tensioner.  The belt is just a single BX88 belt. 91 inches long.   From watching youtube I see the newer mills do have a belt tensioner.  I will have to check with Timberking about tensioner.   I am using a new belt.  Plus I changed out all the fuel hose.
Timberking 1220
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
« Reply #71 on: June 30, 2020, 01:23:05 PM »
I have noticed with my mill, the more the drive belt is flopping around, the rougher the cut. When the tension is adjusted tight enough so the belt isn't flopping about, I get a much smoother cut (finish). With the drive belt flopping, it's like you have a few teeth with too much set. With your drive belt flopping around, your band speed is fluctuating to the tune of the belt flopping about, which would lead to the blade tension fluctuating in the cut, which would also lead to quicker blade fatigue and failure. A smooth running drive belt means a smooth running band speed which gives a smoother cut.
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Timberking 1220
Started by mapletree on Sawmills and Milling
Last post March 06, 2007, 09:02:51 PM
by sgtmaconga
met a guy with a timberking 1220
Started by JamieT on Sawmills and Milling
Last post January 27, 2014, 12:31:40 PM
by JamieT
New TimberKing 1220
Started by jander3 on Sawmills and Milling
Last post July 17, 2010, 10:41:50 PM
by Magicman
Timberking 1220 15' extension
Started by Piston on Sawmills and Milling
Last post July 14, 2008, 08:32:00 PM
by Piston
