Dynamic Green Products Inc.
Author Topic: Wood-Mizer Accurate cuts.  (Read 825 times)
Offline richhiway
  • Rich
« on: June 13, 2020, 06:03:18 AM »
Needed to trim a little off the last board.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Wood-Mizer Accurate cuts.
« Reply #1 on: June 13, 2020, 08:21:24 AM »
Yes Sir, that is a pretty sight.   8)
Offline Banjo picker
« Reply #2 on: June 13, 2020, 10:23:51 AM »
I think thats a pretty common problem for most of us.  We get everything set just right and then in the middle of the night..... the elves come and reset it.  Banjo
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: June 13, 2020, 12:10:13 PM »
With the dimensions that I normally saw I can hit the dog board with the same thickness, but with oddball stuff, the customer and I make decisions as the cant is sawn.
Accuset 2 would be nice but I hope that I never have to upgrade to it.  $$$
Offline Sixacresand
« Reply #4 on: June 13, 2020, 12:39:48 PM »
When you get that kind of consistency, you know got the right blade and everything is adjusted just right.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #5 on: June 13, 2020, 09:04:17 PM »
  Looking good but did you start on a preset mark then end up with the thick dog board? If so you may want to check your starting mark and adjust it down that fraction of an inch. The cuts all look real good. I love those electronic setworks!
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #6 on: June 13, 2020, 09:24:00 PM »
Perfect! Or whoops I should have started a little lower.  :D
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
« Reply #7 on: June 13, 2020, 10:10:39 PM »
That's why I like accuset. It would save that trim cut at the bottom. I used to saw cants like that to get boards until I found that it was often possible to get a defect 2 or 3 boards down that continued down the stack, and ruined most of the pile of wood. One of the things I like about sawing stationary is that I now drag back each board and send the mill on its way down the log whilst I flip the last sawn board knocking the sawdust off, send it down the rollcase and stack it on a pallet, before heading down to catch the mill, drag back the next board and repeat. It's allowed me to scan each board for defects as they are sawn and adjust on the fly if needed, knock off most of the sawdust, and ensure a higher quality product that customers keep coming back for.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Offline richhiway
  • Rich
« Reply #8 on: June 14, 2020, 07:50:16 AM »
I should make a "cheat sheet" It is easy to be off when I do it in my head.
I work alone without hydraulics so I cut the stack and then remove it with the tractor,it saves a lot of time and walking.
Not a real big deal for me to end up with a odd dog board or make the extra cut. If I end up with a thick board I just put in the "project pile" and run it through the planer when I build something.
I would have to be more careful if I cut mobile but I only cut for myself.
The picture was to show how accurate a Wood-Mizer can cut.
Howard, rest up buddy so those fingers heal up well. We are enjoying some great weather, everyone have a good day.
Rich
Woodmizer LT 40
Stihl Chainsaws
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #9 on: June 14, 2020, 08:11:07 AM »
Thin trim cuts seem to often make a favorable impression on my customers.  I can tell either from their comments or them showing it to someone or saving it off with the lumber.
  • Gender: Female
« Reply #10 on: June 18, 2020, 12:04:58 AM »
Yup, Woodmizer cuts very accurately when set up properly with a decent operator, but to be fair you need to flip every second board and see if they still line up... If you are cutting slightly wavy, you won't see it in the same stack you sawed it...
Stuart Caruk
Identifying Wood: Accurate Results With Simple Tools
Started by fstedy on For Sale
Last post December 22, 2019, 12:20:18 AM
by fstedy
What Value $$ or Use from Opening Cut(s) of Log} Barked Wood Cuts.. Fire Wood ?
Started by H60 Hawk Pilot on Forestry and Logging
Last post October 28, 2009, 07:53:44 PM
by H60 Hawk Pilot
Lathe-Mizer - Writing article for The Wood-Mizer Way and need input
Started by bcornelius79 on Sawmills and Milling
Last post February 08, 2011, 02:59:24 PM
by bcornelius79
How Saw Chain Cuts Wood
Started by Gary_C on Chainsaws
Last post August 05, 2008, 08:16:42 PM
by olyman
