Author Topic: Squeaking FAO  (Read 587 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Squeaking FAO
« on: June 13, 2020, 12:02:14 PM »
One of my FAO's has been complaining during the last couple of setups, so it was time....
I had tried to squirt up inside which did no good so I removed the FAO and slid the bottom section off revealing the Acme screw.
I needed a paddle to reach the top end of the Acme screw so what better to use than Walnut. I also greased the sides where the "nut" may rub.
I also greased both sides of the thrust washer below the adjusting nut.  Now it is no squeaks, no jams, no errors.  ;D  There are 5 more FAO's and even though it only took 30 minutes, they will have to squeak and get my attention before they get their turn.  ::)
Offline donbj
Re: Squeaking FAO
« Reply #1 on: June 13, 2020, 01:30:04 PM »
It's that old saying, "squeaky wheel gets the grease". Though an out rigger in this case! :D
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Re: Squeaking FAO
« Reply #2 on: June 14, 2020, 08:01:37 AM »
Squeaky or not, I want FA0s!!! Last winter I spent all my maintenance$$ on truck repair. The year before I did the Crank shaft support bearing. Maybe this coming winter.
mh
Higher than my expectations
Online terrifictimbersllc
    • Terrific Timbers LLC
Re: Squeaking FAO
« Reply #3 on: June 14, 2020, 08:13:12 AM »
I thought from the title there was going to be a mouse in there.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Squeaking FAO
« Reply #4 on: June 14, 2020, 09:44:57 PM »
Mine have grease nipples which I found by accident last week.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Squeaking FAO
« Reply #5 on: June 14, 2020, 10:04:48 PM »
Mine are 2012 models so maybe pre-nipples??
Re: Squeaking FAO
« Reply #6 on: June 15, 2020, 05:06:30 AM »
Mine were 2015, none either. Maybe they will develop?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Squeaking FAO
« Reply #7 on: June 15, 2020, 06:59:08 AM »
I can't see how a zerk could grease the Acme rod because the nut travels.  Hmm, da saga of da hidden nipples continues.
Offline Stephen1
    • muskoka Sawmill
Re: Squeaking FAO
« Reply #8 on: June 15, 2020, 07:27:03 AM »
Im at the shop sawing this week and will be servicing the mill. I will have a look again and take some pics.
 I didnt know about the nipples until the bottom leg fell out when I unscrewed to far.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Squeaking FAO
« Reply #9 on: June 15, 2020, 10:20:04 PM »
My bottom legs will fall out because they ain't attached to anything.  Just floating inside of the main housing.  This is how I reached the Acme screw.  I can't unscrew too far because it will bottom out and stop turning.
