Author Topic: I've said it for years.  (Read 861 times)
Online customsawyer
    • The Custom Sawyer
« on: June 21, 2020, 07:09:27 AM »
I've said for years that fresh cypress cuts so easy you could cut it with the blade on backwards. Well last week I opened a new box of blades and noticed the 4th blade out of the box was backwards. Didn't think much about it. While I was driving the skidsteer I asked my hired man to change the blade. In his defense he's only changed about 4 or 5 so far. Well you know which blade he put on and I just went back to the controls and set up for my next cut. It worked but didn't sound the same. Here is a pic of the blade and the cut.
Y'all say that without pics it didn't happen, so here you are.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: I've said it for years.
« Reply #1 on: June 21, 2020, 07:17:09 AM »
 :P
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: June 21, 2020, 07:49:27 AM »
This is a new technique that I have not tried.  Wonder if it will work with pecan?
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #3 on: June 21, 2020, 07:53:41 AM »
I should have tried it on the liveoak we sawed Friday.  Jake's cut is much straighter than mine with a new blade going the right direction.
That's a good looking cypress log.  A whack of those will make a man happy.
Online customsawyer
    • The Custom Sawyer
« Reply #4 on: June 21, 2020, 07:59:07 AM »
You go ahead and try it. Let me know how it works.
The customer sent 5 semi loads that were loaded a little heavy. He had me cut them all at 1" when I would have rather cut at the standard 4/4 1.125". I ended up cutting a little over 35,000 bf out of those 5 loads.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #5 on: June 21, 2020, 08:02:47 AM »
That log is a smasher!!
D
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #6 on: June 21, 2020, 08:26:41 AM »
Technique doesn't work on Elm, btdt. ;)
Offline caveman
« Reply #7 on: June 21, 2020, 09:13:18 AM »
This straying a bit from the backwards blade.
Jake,
Does your dust chute clog while cutting cypress even with your high hp dust blower?  Does your mill still have the fingers in the dust chute?  That is about the only negative I can think of to sawing cypress is that it will clog the dust chute if it is not cleared frequently.
Caveman
Offline Southside
    • White Oak Meadows
« Reply #8 on: June 21, 2020, 09:39:36 AM »
Just to add to the research data that same technique does not work with White Oak either....
White Oak Meadows
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: June 21, 2020, 09:50:57 AM »
I had a "backwards" blade a couple of weeks ago, but it was a dull one.  I noticed when Luke coiled the blade he made a miscue, recovered, and than coiled the blade.  He then handed it to me to put in the truck and I immediately felt that something was wrong.  It took me a bit to figure out that his "miscue" had reversed the blade.  smiley_headscratch  So far I have never tried to saw with one.  :-\
Offline Bruno of NH
« Reply #10 on: June 21, 2020, 09:54:26 AM »
Frost toothed bands only work in frozen logs
Teeth in
Ask my hired man  :D
They come new inverted
I have to remind him to flip them .
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #11 on: June 21, 2020, 10:59:31 AM »
So if you cut with it backward until it finally gets dull, can you then turn it around and keep cutting?  Twice the life before having to sharpen.  Nice.
But then youd have to buy a backwards CBN wheel to resharpen them.
HobbyHardwoodAlabama.com
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #12 on: June 21, 2020, 11:20:07 AM »
I've only had someone put a band on my mill one time. Taking it out of a flat pack box he managed to get it turned inside out. It cut pine, but not very well. :D
Online customsawyer
    • The Custom Sawyer
« Reply #13 on: June 21, 2020, 12:06:30 PM »
Jake,
Yes my fingers have been removed. Yes the cypress will clog up every part of the dust collection system. The sawdust is just to wet and sticks to everything. I had to blow it on the ground and shovel into my
The pic is a little miss leading. That log was only about 12" dia. on the small end.
YH I only tried the one pass. It made it but she was a bit on the wavy side.
Online Old Greenhorn
« Reply #14 on: June 21, 2020, 01:26:11 PM »
Couldn't you just put the CBN wheel on backwards also? :D ;D
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here. OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker
Offline Southside
    • White Oak Meadows
« Reply #15 on: June 21, 2020, 01:31:05 PM »
Actually wouldn't it automatically be sharpening it the whole time?  ;D
White Oak Meadows
« Reply #16 on: June 21, 2020, 03:19:48 PM »
Cypress is probably like grits. You wouldnt need any teeth to eat them.
Offline EOTE
  • I don't suffer from insanity-I enjoy every minute.
    • Weather at EOTE
« Reply #17 on: June 21, 2020, 04:26:53 PM »
Backward blades don't work in SYP.  >:(
EOTE (End of the Earth - i.e. last place on the road in the middle of nowhere)  Retired.  Old guys rule!
Buzz Lightsaw, 12 Mexicans, and lots of Guy Toys
Offline barbender
« Reply #18 on: June 21, 2020, 06:23:09 PM »
I can confirm that backwards blades make blue smoke on white oak😁
Three years later
Started by moosehunter on General Board
Last post April 25, 2007, 09:54:07 AM
by bedway
new years eve fun
Started by 2308500 on Forestry and Logging
Last post January 02, 2017, 04:51:15 PM
by 2308500
In 50 years
Started by goose63 on Tree, Plant and Wood I.D.
Last post July 25, 2014, 05:16:14 PM
by goose63
after 10 years
Started by hiya on General Board
Last post January 30, 2006, 10:19:54 AM
by MemphisLogger
