Author Topic: Husqvarna Weed Whacker Dead  (Read 1064 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« on: June 23, 2020, 01:31:58 PM »
I have a Husqvarna 326RJX weed whacker that has me at wits  end.     It has spark, gets gas into the cylinder and has good compression, yet  will not fire over.    The gas is good and I replaced the carburetor, filter, primer bulb and the hoses.       It just spins when pulling the starter rope and does not even attempt to start.   I even tried startin g fluid with no effect either.
I'm not ready to spend $400+ on a new one.   Any ideas?
Wood-Mizer LT40 Super- Wide HDG38
Lucas Dedicated 60" Slabber
Offline btulloh
Re: Husqvarna Weed Whacker Dead
« Reply #1 on: June 23, 2020, 01:38:07 PM »
Sounds frustrating. Bound to be a solution though.
Spark, fuel, and compression. All the requirements except for air. Have you checked out the air filter, etc.?
HM126
Offline sawguy21
« Reply #2 on: June 23, 2020, 02:06:40 PM »
Leave the starting fluid alone, that is a quick way to destroy a 2 stroke engine as it dries out  the gaskets and seals. What is 'good compression'? It needs at least 110 psi to run. Did it stop suddenly or just refuse to start? Did you replace the spark plug?
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #3 on: June 23, 2020, 02:29:07 PM »
Hasn't run since last year.   If I remember it wouldn't start when I went to use it.       Spark plug, air cleaner, fuel lines, fuel filter, priming bulb and carburetor are all new.     Gas is good.  Husky chainsaws fire right up using same gas.     Tester on plug line shows good spark.    Compression after 4 to pulls is 120.
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #4 on: June 23, 2020, 05:21:17 PM »
Have you tried magic beads?  It sounds like standard engine medical practices are failing at the moment.
Offline Hilltop366
« Reply #5 on: June 23, 2020, 05:27:01 PM »
That leaves timing and crankcase vacuum leak.
X2 in the starting fluid, there is no oil in there. I will prime with mixed gas.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #6 on: June 23, 2020, 05:59:04 PM »
Tester on the plug line?  What about spark at the plug's electrode?  Sounds like a new spark plug is needed...
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #7 on: June 23, 2020, 06:09:56 PM »
Offline Hilltop366
« Reply #8 on: June 23, 2020, 06:18:01 PM »
I get what Corley5 is saying, new plug does not always mean a good spark plug.
Offline JJ
  • Gotta figure this out
« Reply #9 on: June 23, 2020, 06:22:26 PM »
Plugged spark arester on exhaust?
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #10 on: June 23, 2020, 06:42:49 PM »
If there was a vacuum leak, I wouldn't expect it to hold compression.     I need to look at timing.  I thought it was fixed.   I wasn't aware of adjustment.
Offline Corley5
    • Whittaker Farms
« Reply #11 on: June 23, 2020, 06:44:12 PM »
Yup.  New doesn't mean it's any good.  No need to yell ::)
Offline Corley5
    • Whittaker Farms
« Reply #12 on: June 23, 2020, 06:49:55 PM »
Have you checked for spark at the plug's electrode?
Offline Hilltop366
« Reply #13 on: June 23, 2020, 07:02:36 PM »
Vacuum leak would be at the crank seals or cylinder base, can still have compression.
Timing is not usually adjustable but sometimes can be off, caused by flywheel spinning on the crank shaft bit or faulty electronics.
Offline TroyC
« Reply #14 on: June 23, 2020, 08:41:41 PM »
Hilltop is right about the timing. I've seen several chainsaws and weedeaters that the flywheel has spun on the crankshaft. On a weedeater I just repaired, the keyway is actually molded into the flywheel. Since it is aluminum it sheared and spun easily. I ground out a keyway slot in the flywheel, made a key and put dab of JB in and tightened it up good.
Like yours, mine would spark but not fire, even with starting fluid. Check the keyway!
Also check spark plug for proper spark. Sometimes coils get weak.
Offline 69bronco
« Reply #15 on: June 24, 2020, 07:46:58 AM »
Check the exhaust port for mud daubers.
Offline farmfromkansas
« Reply #16 on: June 24, 2020, 10:14:05 AM »
Used to hang out at the local garage when I was young.  They had a B&S engine one time that would not run, no matter what.  They finally tried putting a new flywheel on it, and it started right up.  The magnet somehow had lost it's power and would not create enough spark to start the engine.
Offline Gere Flewelling
  • Hobby Miller
« Reply #17 on: June 24, 2020, 09:47:53 PM »
My vote is with JJ.  I think the exhaust port or muffler is plugged.  Been there and been fooled by that before.
Old 🚒 Fireman and Snow Cat Repairman
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #18 on: July 09, 2020, 06:07:06 AM »
I'll be with the plugged exhaust gang. Either mud daubers or the spark arrestor plugged with carbon. Take the muffler apart and check it.
mh
Higher than my expectations
Offline Dakota
  • Swing'en in South Dakota
« Reply #19 on: July 09, 2020, 07:48:18 AM »
faulty on-off switch?
Dave Rinker
I'll take a weed whacker...
Started by JohnM on General Board
Last post October 17, 2013, 10:21:50 PM
by easymoney
Husqvarna 385xp / 390xp "dead saw salvage" project(s)
Started by weimedog on Chainsaws
Last post April 01, 2017, 02:05:40 PM
by weimedog
8 ton vibratory gravel whacker...
Started by Dave Shepard on General Board
Last post November 02, 2013, 07:06:17 PM
by Dave Shepard
Weed ID
Started by DouginUtah on General Board
Last post June 09, 2010, 10:37:14 AM
by Coon
