(Image hidden from quote, click to view.) The small band is fixed to the inner band at the top, the lower connection goes to the control rod. The large band is fixed at the top.
the brake band is the one on the outside and it is released to free spool, the ones on the inside are the clutches they rotate constantly then when they are engaged it turns the drum and pull the cable in I have a pic of the controller in my galley , the pressure is about the same as the old hydrolic brakes on a car
the smaller one probably helps tightens the bigger one , you will probably need to get your controller working to make it work right its probably not froze just need pulled apart and cleaned
Started by Stamp on Job Opportunities
Started by Gary Davis on Forestry and Logging
Started by coxy on Forestry and Logging
Started by mechanics wife on Forestry and Logging
