Author Topic: Gearmatic specialists, hydraulics?  (Read 4481 times)
Offline mike_belben
  • Pulp Friction
Re: Gearmatic specialists, hydraulics?
« Reply #80 on: March 15, 2021, 04:05:05 PM »
In america we call them contactors also.  Sounds like youve got it licked max.  smiley_thumbsup
Psalm 37:16
Offline Satamax
  • Living in Absurdistan!
« Reply #81 on: March 15, 2021, 05:50:27 PM »
Well, i discovered something. The o ring on the drum side of the clutch and brake compartment is gone!  ::)
Anybody knows the joint's diameter and circumference of the drum's seal?
Offline Ed_K
« Reply #82 on: March 16, 2021, 07:49:10 AM »
 I looked all thru my book and all I can do to help is the large o-ring is part # 50347 and the smaller one is part # 50331. These are on the model 19.
Ed K
Offline Satamax
« Reply #83 on: March 16, 2021, 08:30:21 AM »
Thanks a lot Ed.
I have G281 as a number for this O ring.
I would like to know the dimensions, to glue one myself! I'll glue it on the drum, oil it then push it in.  Instead of taking everything appart!
Offline Satamax
« Reply #84 on: March 18, 2021, 10:24:36 AM »
The drum's O ring being missing bugs me big time.
Anybody here has changed his?
And there is the worn out and bent splines on the shaft, which annoy me too.
Offline mike_belben
  • Pulp Friction
« Reply #85 on: March 18, 2021, 05:08:02 PM »
In the american southeast that is a highly technical condition known as 'wallered out.'
'Snawt good.
Psalm 37:16
Offline Satamax
« Reply #86 on: March 18, 2021, 05:37:42 PM »
I had to look at the "translation" well, that's after a lot of translation! :D  ;D
Offline Satamax
« Reply #87 on: March 22, 2021, 01:54:19 PM »
Guys, it's chtuck!
Is there a trick to get those out ?
Offline Satamax
« Reply #88 on: March 23, 2021, 10:31:33 AM »
It's doing my head in.
I have a part number on the housing D-1.9534, which leads to nowhere, but may be caterpillar. Looked cat adapter plates.
https://avspare.com/caterpillar/sebp1345/sebp1345035/#SEBP13450350
And it seems there is a # 21 or 15 bolt. Which i can't see how to unscrew.
It doesn't look like this one either.
https://en.av-gk.ru/catalog/komatsu/td8g/17-060/
There is the bolt on this one
https://avspare.com/catalog/case/57194/5647562/843361/
and this one too.
https://avspare.com/spare/case/d46289/
Offline mike_belben
  • Pulp Friction
« Reply #89 on: March 23, 2021, 11:30:35 AM »
Cant help ya there max.  Any chance its hung on that center shaft or maybe snap-ringed from the interior?
Psalm 37:16
Offline Satamax
« Reply #90 on: March 23, 2021, 12:24:02 PM »
I don't know. I just turned a bolt chaser out of some brass. And pushed the four remaining bolts out. To no avail.
Offline Satamax
« Reply #91 on: March 23, 2021, 05:26:48 PM »
So finally, it is all appart.
The two hidden screws were in the two big holes of the rear mounting stubs.
16 mm hex head, or 5/8" I ground a 17 mm one.
I still need to remove the oil seal.
Work on the input shaft, which has a good 2 mm runout.
I will cut the splines out. Buy a proper shaft, 21 splines 1" 3/8. Bore it to the right diameter, bar a few thousandths.  Heat shrink it on the shaft, weld it to it. Then dress the welds. Redo the oil seal "journal" I have a bit of room there. I think i can do something. Or sleeve it.
I have discovered that the brake doesn't hold, while lifting the winch to turn it over. I will need to change the input  gear bearing too.
Lotsa work ahead!
Offline Ed_K
« Reply #92 on: March 25, 2021, 06:21:23 AM »
 That back plate doesn't look anything like my 19, did you figure out what it is? I don't have a hydro access like that.
Ed K
Offline Satamax
« Reply #93 on: March 25, 2021, 08:12:50 AM »
Ed, sorry, i don't know what it is. May be some caterpillar. The number seems to lead that way.
What do you mean by "hydro access" ?
Offline Ed_K
« Reply #94 on: March 26, 2021, 07:55:37 AM »
 On the left side of the plate there's what looks like a cat hydraulic bolt up for a hose.
Ed K
Offline Satamax
« Reply #95 on: March 26, 2021, 09:46:00 AM »
Sorry to be dumb. I don't see what you mean.
Offline Ed_K
« Reply #96 on: March 27, 2021, 05:43:40 AM »
 I went back to reply 87 and I'm wrong, what i was looking at are just mounting brackets. Sorry for the confusion :(.
Ed K
Forest Health & Aerial Survey Specialists Positions in CA--deadline November 20
Started by Stamp on Job Opportunities
Last post November 09, 2009, 10:53:00 AM
by Stamp
gearmatic 119
Started by coxy on Forestry and Logging
Last post March 02, 2014, 04:29:16 PM
by lumberjack48
Gearmatic 19
Started by mechanics wife on Forestry and Logging
Last post September 30, 2010, 05:46:46 PM
by Autocar
Gearmatic 19
Started by Caseybow123 on Forestry and Logging
Last post June 23, 2017, 10:22:27 PM
by Spartan
