Dynamic Green Products Inc.
Author Topic: goose neck into logging trailer  (Read 6774 times)
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: goose neck into logging trailer
« Reply #140 on: January 17, 2021, 11:25:51 PM »
YH, this is your friendly reminder to oil that trailer deck soon.  Im a few years late on mine and wish i wasnt.
Yes, I agree.  I have been letting it go too long because I have some pretty big holes in the deck from where big butt flair logs have punched through the boards.  I’ve got some work to do already.  I have been meaning to to replace the decking, but I have until next inspection, in August, to deal with it.
I am almost thinking of removing the decking altogether and leaving it off.  But I’m worried that without the shock absorbing layer of wood, my steel would get damaged.  Any thoughts?
YellowHammerisms:
Take steps to save steps.
If it won’t roll, its not a log; it’s still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, they’re burned, and you can’t fix them.  Don’t burn the cookies.
Offline Tacotodd
  • To learn and help
« Reply #141 on: January 18, 2021, 11:43:03 AM »
YH, steel is pretty tuff stuff,, so I hope/know you’re just yanking our chain!
Trying harder everyday.
Offline mike_belben
  • Pulp Friction
« Reply #142 on: January 18, 2021, 12:02:38 PM »
Well.. With just crossmembers itll become just a two trick pony (logs or lumber only) but if you only need your pony to do two tricks...
How will you keep the rusty steel from staining your lumber packs?  You truly dont need it for anything else? Moving tractor or cars ever?
Revelation 3:20
Offline Walnut Beast
« Reply #143 on: January 24, 2021, 04:15:41 AM »
anyone have tips on the oil bath hubs?
Have a Diamond C trailer with the standard plastic caps and want to upgrade to Valcrum’s premium aluminum alloy oil hubcaps? Select your compatible Lippert/Dexter axle here to order the correct Valcrum hubcap for your trailer for an easy upgrade.
« Reply #144 on: January 24, 2021, 04:17:54 AM »
Offline doc henderson
« Reply #145 on: February 11, 2021, 04:08:47 PM »
found some great test "logs" with almost no taper to test out my bunks.  a little heart rot all the way through,  and it is a "black" something.  came from a grain elevator.  My buddy Dallas, did not want to see them go to waste.   no leaves or bark, but some wheat ran out of the center.  had linear rings, not concentric.
it was an hour drive.  the uprights pulled off nice.  we had 3 sold before we got home to friends we thought might need them.  hundred bucks a piece.  a day later Dallas's wife got 200$ each for 3 more on Craig's list, but they have not been picked up yet.  got some dirt on the paint, and they worked well.  will prob. sell as is, although @YellowHammer would prob. quarter saw, and @Southside would house chickens in them.   :D :D :D
Offline Southside
    • White Oak Meadows
« Reply #146 on: February 11, 2021, 04:13:39 PM »
Seems to be ring diffuse? Probably very rot resistant
White Oak Meadows
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #147 on: February 11, 2021, 06:10:47 PM »
I would love to get my hands on that score.
Offline mike_belben
  • Pulp Friction
« Reply #148 on: February 11, 2021, 06:54:33 PM »
all i see is a trailer full of cash.
Revelation 3:20
« Reply #149 on: February 11, 2021, 11:02:15 PM »
All I see are some well made and very sturdy metal bunks!
YellowHammerisms:
Offline scsmith42
    • Whispering Pines Farm
« Reply #150 on: February 13, 2021, 03:45:00 AM »
Looks great Doc!
Tom's 3638D Baker band mill
« Reply #151 on: February 13, 2021, 09:29:34 AM »
the same culvert pipe is 540 bucks at a farm store each.  good deal at 200 bucks, and not buried for a thousand years.
Offline JuanChair
« Reply #152 on: February 15, 2021, 11:53:44 AM »
I’ve hauled many million pounds of logs and lumber in my PJ Gooseneck setup, for several years, maybe 400 miles a week on a DOT inspected truck and trailer.  This is a very safe and extremely strong setup, with 4 inch heavy wall tubing for bunks, and removable side supports for hauling packs of lumber.  The bunks slip on heavy stubs.  The whole thing sits in the stakes pockets and can removed if desired.  When hauling lumber, just slip the bunks off the studs and leave the main assembly on the trailer to allow forklifts to get their forks under the pallet.
I have many pictures with measurements in my galley, and several people have reproduced this design with success.
https://forestryforum.com/gallery/thumbnails.php?album=5893
The side supports slip over stubs.
The studs are through welded and inset Inyo the 4x4, it is not just fillet welded to the top.  In order for the stud to come off, it would literally have to rip itself through the steel square tubing.
Great Idea and thank you for sharing it with us.   I'm  researching all the equipment and "things" I will need to get started and this helps a lot.
Offline Biocmp
  • Taking steps on the path
« Reply #153 on: February 17, 2021, 12:15:45 PM »
How tall are your stubs? Side supports?  I ask because you mentioned when you have a really big log that is too heavy to lift over the supports, you remove them and roll it off.  I'm curious about how you roll over the rather sizable stubs?  They look like they stick up at least 6-8+ inches from the cross members
« Reply #154 on: February 17, 2021, 07:41:28 PM »
It's easy.  If you have a log on the trailer heavier than your loader can deadlift, using the forks on the loader or tractor, push and slide the log against the far side of the trailer against the stubs.
Then ease the forks under the log, and have the tips extend slightly outboard of the trailer frame.  Gently pry the log over the stubs using the forks as a huge crowbar, and gently roll it over the stubs, and have it thump to the ground.  You can get huge leverage like this to pry off all even the biggest logs.  Also, use the heel of the loader forks to contain the trailer from trying to flip over, if the log weighs more than the trailer.
Otherwise, if the logs are extremely huge, cut a piece of railroad crosstie into the shape of a wedge taller than the stubs, then simply roll the log off on the wedge ramp, over the tops of the stubs.
This is why I'm not a big fan of grapples for unloading logs, the grapples are heavy so reduce the lifting capacity of the loader, and they also attach the tractor or loader directly to the log, if they are used to actually grapple the log.  If the log is grappled off its center of gravity, it can roll the tractor.  Using forks, if the logs isn't being lifted in its CG, the forks can be rapidly dropped and moved to the side.  No big deal.
Heres are some pics of some of the logs I've unloaded.
A load of big sycamore:
Here's a very heavy oak log I rolled off the trailer with wooden wedges.
YellowHammerisms:
« Reply #155 on: February 17, 2021, 07:43:57 PM »
Love seeing those pictures YH. How long is your trailer?
« Reply #156 on: February 17, 2021, 10:53:51 PM »
It’s a 25 foot PJ.
For reference, I’m 6’5” and you can see how big the oak logs is.  For unloading it, I placed a few cut off stumps under the trailer frame so that when all the weight was to one side of the trailer, the frame would rest on the stumps.  That way I wouldn’t risk bending the frame or flipping the trailer. I then put the wedges on, and crowbarred it right off the trailer with the forks.
Later, I found out that the guys at the local mega mill were taking bets if I would buy it, if I could get it home, if I could unload it, and if I would damage anything in the process.  Only one fellow bet all in on me, and when I showed back for another load of logs later in the day, he was a happy guy. :D
YellowHammerisms:
Offline Biocmp
« Reply #157 on: February 18, 2021, 07:36:44 AM »
Thanks Yellowhammer, that is incredibly helpful and makes perfect sense. I'm new to this world and it's easy to get caught up in trying to buy equipment big enough to lift these 1-off logs but there's a lot of value in ingenuity with leverage/mechanical advantage.
So much to learn....
Appreciate you sharing all this information.
ATV Logging trailer
Started by jerry sundberg on General Board
Last post January 20, 2019, 06:32:31 AM
by jerry sundberg
logging/forwarding trailer
Started by sawmillsi on Forestry and Logging
Last post November 03, 2009, 04:56:15 PM
by Stephen Alford
logging Power trailer
Started by rasorbackQ on Forestry and Logging
Last post December 23, 2015, 06:28:36 AM
by snowstorm
Wanted small logging dray/ forwarding trailer
Started by CX3 on Wanted
Last post December 06, 2010, 09:56:57 PM
by CX3
