LT15GO Dimensions
Started by matt3737, June 29, 2020, 03:24:11 PM
matt3737
What is the height of the top of the bed rails (where the log sits) off of the ground on the LT15GO?  I understand the answer may vary slightly depending on grade and how the jacks are set up.
I own a LT15 and have ordered the trailer package but it hasn't arrived yet.  The mill will sit on my property most of the time, but it'll be helpful to have the ability tow it to another location from time to time.  I'm building a small pass-through shed that I can park the head unit underneath when the mill is parked on my property.  This will keep the bulk of the weather off of the most significant parts of the mill.  While it's parked in this location, I'd still like to be able to use the mill at its maximum capacity.  There's a post on the saw head that sticks above the water tank when the head is lifted to full height.  I want to ensure that post can still clear the shed roof when the head is raised to max height.  In order to determine that minimum height for the shed roof, I need to know how high the bed rails sit off of the ground when the LT15 is mounted to it's trailer.  I can figure the rest out from there.  Thanks guys!
