Dynamic Green Products Inc.
Author Topic: best bang for the buck for sharpener and setter?  (Read 1929 times)
Offline farmfromkansas
Re: best bang for the buck for sharpener and setter?
« Reply #20 on: July 15, 2020, 07:51:57 PM »
Just checked the Timberwolf site, and they offer blades, sharpening services, a dual tooth setter, and cams for both Cooks and Woodmizer sharpening systems.  But did not find a sharpener.  Price of their dual tooth setter is 1145, and the cam is 42 each. So if you use their blades, you can get a cam to sharpen their blades but have to use a Cooks or WM sharpener looks like.
Offline Durf700
« Reply #21 on: July 15, 2020, 08:22:21 PM »
I will take a look at them.
thanks
Offline Tristen
  • Location: Donovan Illinois USA, 2 hours south of Chicago
« Reply #22 on: November 20, 2020, 10:11:49 PM »
First let me just say,  I am not trying to promote wooland mill or my YouTube channel. That being said, the Woodland mills tooth setter is cheaper than most others.  The automatic blade sharpener is also cheap compared to the others, then compare the prices of replacing grinding stones and woodland mills is a great buy.  I have just posted a youtube video on blade setting with woodland mills,  I have only set a few blades myself it is very easy and it will allow you to play around with the degree of your set,  find what works best for you and your type of logs.  I have not yet tried to set a blade for speed however it is less than 5 min and it is easy after the first time you do it.
Interest; Wood mizer LT35 HD, Husky chainsaws, Firewood, sustainable logging, lumber, Kubota Bx25, Kubota B1700.
Offline Durf700
« Reply #23 on: November 22, 2020, 02:36:58 PM »
I purchased a BMS 250 automatic CBN sharpener through woodmizer! I love it!   works great!
Offline Wintergreen Mountain
« Reply #24 on: November 22, 2020, 02:53:59 PM »
 Good for you!
   You won't regret it.
   I bought a Cat Claw set a couple of years ago. Works perfect for me.
  It is what you have and getting used to it that counts, Not the Brand you get.
 Leon
1920 Ford 4x4 tractor, forks & bucket. 2010 36" Turner Mills band mill. Cat-Claw blade sharpener. Cat-Claw Dual Tooth Setter. Cat D3 crawler dozer. Cat 215c excavator, Ford L9000 dump truck. Gardner Denver 190 portable air compressor. KatoLight 40Kw trailer mounted gen set. Baker M412 4-head planer.
Offline Walnut Beast
« Reply #25 on: November 22, 2020, 04:00:30 PM »
Hudson has a new sharpener they claim will sharpen band blades and saw chains. Not sure why there not a sponsor. I would personally stick with a sponsor off of the forum
Bang for the Buck!
Started by Charles135 on Sawmills and Milling
Last post May 19, 2012, 03:00:10 PM
by Charles135
What brand saw do you use? What's the best bang for your buck?
Started by RDevonshire94 on Chainsaws
Last post February 24, 2020, 10:42:13 PM
by Andyshine77
Firewood Conveyors- Who is giving the most bang for the buck currently?
Started by labradorguy on Firewood and Wood Heating
Last post July 17, 2015, 12:55:02 PM
by labradorguy
Buck ninety eight dual tooth setter
Started by pineywoods on Sawmills and Milling
Last post September 24, 2018, 09:11:29 AM
by Stephen1
