Author Topic: Screwin dock deck, how many bolts should I use?  (Read 385 times)
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« on: July 08, 2020, 12:12:15 AM »
Narrow end is 54"
Wide end is 148"
On the narrow end do I need bolts in the middle as well? 3" angle is roughly 2' spacing.
On the wide end do I need bolts all the way across? 3" angle spacing is roughly 3'.
I'm putting 3 bolts per 2" x 12" board.
Using 5/16 m18 stainless tapered bolts with stainless nylon locknuts.
Offline Sedgehammer
Re: Screwin dock deck, how many bolts should I use?
« Reply #1 on: July 09, 2020, 04:03:56 PM »
Here's where I'm at. Didn't screw middle down on the narrow end
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: July 10, 2020, 06:59:12 AM »
Looks good!
If it starts to raise in the middle, you can put a couple of bolts in it then, but looks good as is!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Don P
    • Calculator Index
« Reply #3 on: July 10, 2020, 07:23:38 AM »
This will be interesting to watch, and keep us posted in a coupla few years as this weathers. I suspect the wide boards with wide bolt spacing is going to split a number of the planks as they see repeated wet/dry cycles. I would have used 6" wide decking, so this is a learning op.
Offline Sedgehammer
« Reply #4 on: July 10, 2020, 08:24:45 AM »
I know the 6" is preferred per what you said. I just don't like the way it looks. I'm using stainless so I can remove a board if needed and not have to drill new holes as the self tapers rusted and twisted off. Hopefully with recoating it a few times a year that'll be minimized. As you said, time will tell.
Offline gspren
« Reply #5 on: July 10, 2020, 08:31:37 AM »
Are you putting anything on it to prevent it getting slippery?
Offline Sedgehammer
« Reply #6 on: July 10, 2020, 09:04:38 AM »
Nope.  Didn't think that would be an issue to be honest. No complaints yet anyways.  Something I need to keep in mind though. Thanks
Sittin on the dock-a-the.....
Started by Tom on The Outdoor Board
Last post May 05, 2006, 06:05:45 PM
by Den Socling
Chestnut Dock Poles
Started by terrifictimbersllc on Sawmills and Milling
Last post April 01, 2012, 04:55:31 PM
Time to re deck the deck
Started by rimshot on Sawmills and Milling
Last post October 01, 2013, 06:43:41 PM
by rimshot
Lag bolts
Started by Hale87 on Timber Framing/Log construction
Last post July 24, 2016, 01:57:13 PM
by Hale87
