Author Topic: Comet Neowise star gazing  (Read 827 times)
Offline Nebraska
  • Lurked for quite a while, learning !
« on: July 17, 2020, 11:33:06 PM »
Wife and I drove down the road half a mile to a field approach (our grove was in the way) . We actually were able to spot it. It is below the big dipper just about halfway up from the horizon beneath the two bottom side stars of the dipper. 30 ish degrees up from the  horizon ... You could see it with the naked eye, but it was better with some average binoculars. A decent rifle scope would work. Kind of a smudge trailing a pin point of light. FYI 10:17 pm. When we spotted it... Should be visible for a coupleasure weeks. Lots of humidity in the atmosphere didn't help the view. Wish I was out west.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Comet Neowise star gazing
« Reply #1 on: July 18, 2020, 08:03:35 AM »
I heard about it being visible a couple of days ago, and have been going out to try and spot it, with no luck!
I'll be out there again tonight!
Thanks for giving a direction in which to focus on!
I can see the Big Dipper anytime it's dark and not cloudy!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Patrick NC
« Reply #2 on: July 18, 2020, 08:15:32 AM »
Weíve been waiting to see it also, but itís been cloudy with thunderstorms the last couple nights here. Hopefully it will be clear tonight. We have a fairly expensive telescope that we bought for my stepdaughter when she went through her ďI want to be an astronomer ď phase. If I can find it, it should give us a pretty clear view.
Offline Nebraska
« Reply #3 on: July 18, 2020, 09:22:35 AM »
Telescope will help a bunch, so would dry air.
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« Reply #4 on: July 18, 2020, 09:27:46 AM »
Too much light pollution here so far, but will try again. Thanks fir the heads up.
Offline btulloh
« Reply #5 on: July 18, 2020, 09:30:19 AM »
So far, clouds, humid air, light pollution have shut me down. Iíll keep trying. Last night was supposed to be the best night but cloudy here.
HM126
Offline Chuck White
« Reply #6 on: July 18, 2020, 03:06:20 PM »
Can it be made out to be a comet without using a scope?
Can you see the tail without a scope?
All I have is a pair of 10-power binoculars!
~Chuck~
Offline btulloh
« Reply #7 on: July 18, 2020, 04:07:14 PM »
Supposedly you can see the tail pretty well with the 10x bino's.  May help if you have a tripod for them, or something to help stabilize.
Offline SunnyHillFarm
« Reply #8 on: July 18, 2020, 04:38:50 PM »
I viewed it last night with 10X50 s. I could not see it with out the bino's. The location given is spot on. In WNY it was visible just before 10PM. A tripod would help. The tail is distinguishable but faint.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #9 on: July 18, 2020, 09:22:49 PM »
I saw it 2 nights ago clear as can be. Binoculars made it clearer for sure.
Offline gspren
« Reply #10 on: July 18, 2020, 10:14:54 PM »
We just came in from seeing it. With binocs it was easy to find but don't think I could have found it without, directly below the big dipper.
Offline Ed
« Reply #11 on: July 19, 2020, 01:40:07 AM »
Went behind the shop and viewed it tonight, barely visible without binoculars.
Very cool with the binocs.
Ed
Offline Chuck White
« Reply #12 on: July 19, 2020, 06:34:39 AM »
Couldn't make it out last night, it was sort of overcast up there so nothing was clear!
Will go out again tonight!
~Chuck~
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #13 on: July 19, 2020, 06:57:57 AM »
Visiting with family last night, we were all able to view the comet using a set of binoculars,
D
Offline Chuck White
« Reply #14 on: July 19, 2020, 03:41:35 PM »
Thanks for the diagram Dan!
I was looking in the right area last night, but all I could tell was that there was something there!
Like I said it was a little cloudy or overcast there, I could barely see through it!
Will look again tonight!
~Chuck~
Offline Downstream
« Reply #15 on: July 19, 2020, 11:43:52 PM »
Wife and I stay out tonight in northern Illinois to see if it was visible and sure enough it was.  Visible faintly with naked eye but clearly seen with our nicer binos.  Very cool to add to list of things we have seen like meteor showers, total eclipse, northern lights.
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
Offline Chuck White
« Reply #16 on: July 20, 2020, 06:57:58 AM »
Couldn't see any stars at all last night, the sky was completely clouded over in this area!  ::)
~Chuck~
Offline btulloh
« Reply #17 on: July 20, 2020, 07:07:52 AM »
I'm going to have to go somewhere to see it.  The light pollution here makes it impossible.  Last night was clear, but I really couldn't see any stars at all in that direction.  It's just too built up around here now.
HM126
Offline Chuck White
« Reply #18 on: July 21, 2020, 06:39:15 AM »
No stars at all, again last night! ::)
~Chuck~
Offline Chuck White
« Reply #19 on: July 22, 2020, 06:38:19 AM »
It was nice and clear last night, went out and it only took me a minute or so to locate the comet!
From my position, the comet appears to be going directly away from me!
Kind of reminds me of when I was in the Air Force and had the opportunity to look directly into the exhaust end of a jet engine!
Made me feel pretty good being able to finally see it!
~Chuck~
Comet watching
Started by Ianab on The Outdoor Board
Last post January 19, 2007, 11:05:22 PM
by Ianab
Comet watching
Started by Ianab on General Board
Last post December 24, 2011, 12:57:52 AM
by Ianab
Comet ISON
Started by Ernie on General Board
Last post November 16, 2013, 05:22:30 PM
by Ianab
thumbup
A Comet is examined today
Started by Tom on General Board
Last post July 06, 2005, 08:00:15 AM
by Tom
