Author Topic: EZ Boardwalk  (Read 1408 times)
farmfromkansas and 1 Guest are viewing this topic.
Offline macminn18
Re: EZ Boardwalk
« Reply #20 on: September 07, 2020, 08:42:01 PM »
I just picked up a used EZ Boardwalk mill. The gentleman was upgrading to an automated mill. I went through the operation with him, pretty straight forward.  Is there a manual available for this mill?
Online trimguy
Re: EZ Boardwalk
« Reply #21 on: September 07, 2020, 09:01:48 PM »
Congradulations on the mill !! EZ boardwalk is a sponsor ( on the left ) . I would think you could get that information from them.
Offline Nebraska
  • Lurked for quite a while, learning !
Re: EZ Boardwalk
« Reply #22 on: September 07, 2020, 09:44:45 PM »
There isn't much of a  manual,  just call them and let them know you bought the mill. They will answer questions and help you out, as will folks around here as well.  @macminn18  Congrats on your purchase good luck with the mill.
Offline TroyC
Re: EZ Boardwalk
« Reply #23 on: September 07, 2020, 11:52:20 PM »
@macminn18  My EZ came with the engine manual in a folder, basically that's it. Level the mill, start cutting. You'll figure it out as you go along. Lots of help here on the forum, just ask. The EZ offers a lot for a manual mill. Congratulations, safe cutting! Enjoy!
Online hopm
Re: EZ Boardwalk
« Reply #24 on: September 08, 2020, 12:47:40 PM »
40 or Jr?
Offline Bstueve
Re: EZ Boardwalk
« Reply #25 on: September 11, 2020, 07:41:46 PM »
On my 40, the log turner tube slides in between the ears and the pin traps the turner tube and keeps it from kicking out.  The bottom of the log turner ears stab into the ground.  The hook goes under the frame and the frame and the frame ears slide up the log turner tube which acts like a jack leg.  Lift rear of mill until the axle rolls under frame.
Still 261cm, JD 1025r, Hoping to add boardwalk bandmill soon.
Offline TroyC
Re: EZ Boardwalk
« Reply #26 on: Yesterday at 10:57:29 PM »
Bstueve- thanks for the explanation on lifting the mill with the turner. Makes sense with the explanation. First thought would be that mill would tip sideways if supported from front jack and rear lifter, but I guess supporting mill on 2 front screw levelers would prevent tipping. What a simple but useful design!  Thanks again!
newbie questions 1220TK or Boardwalk 40 or Boardwalk Jr
Started by DDobbs on Sawmills and Milling
Last post August 12, 2020, 05:59:21 PM
by farmfromkansas
New EZ Boardwalk
Started by kettlekorn on Sawmills and Milling
Last post March 31, 2015, 01:27:26 PM
by kettlekorn
ez boardwalk
Started by addicted on Sawmills and Milling
Last post August 01, 2010, 11:00:06 PM
by paul case
ez boardwalk 40
Started by millstead on Sawmills and Milling
Last post August 06, 2012, 07:13:13 PM
by nlrwrangler
