Dynamic Green Products Inc.
Author Topic: Now it's my turn, teak sawmillshed, lol  (Read 4092 times)
Offline teakwood
  • Switzerland
« on: August 09, 2020, 09:25:07 AM »
My layout is way off because it wasn't planed to have a sawmill operation. the log yard is in the middle the sawmill on the left side and the lumber storage on the right side, so it was very inconvenient and inefficient to move the lumber 30m on my pickup.
Because of the hard situation we all face this year i didn't want to spend much money on this build so i decided to go with wood instead of steel because thats what i have for free on my plantations. A teakwood sawmill shed! you guys must think that i went bananas
It's 4 corner posts, which two of them are 6x6 teak posts on top of the concrete wall and two 9x9 ironwood pillars which go 1m into the ground, then two 9m 6x8 teak beams and the rafters on top, pretty simple.
Maybe you see the yellow line on the ground, that's the circumference of the new roof, the two oil buckets is where the ironwood posts go
the beams i had already posted in another topic
Starting with the wood joints, real carpinters work, which i have never done before. they turned out astonishingly nice, it's very very slow but i'm absolutely pleased with the results!
Offline Nebraska
  • Lurked for quite a while, learning !
Re: Now it's my turn, sawmillshed
« Reply #1 on: August 09, 2020, 09:35:06 AM »
Nice work!
Offline barbender
« Reply #2 on: August 09, 2020, 10:03:07 AM »
Gosh! Timber framed teak sawmill shed! Those joints look great👍👍
Offline teakwood
  • Switzerland
« Reply #3 on: August 09, 2020, 10:45:22 AM »
the structure over the concrete is done, now to the harder end. need to do some pockets and cuts in the ironwood. they weight around 300-400kg so there is no bringing them into the wood workshop and tossing them around.
had to make my own teak dowel pins, thanks youtube
the ironwood, they are another chapter!
the vegetable harvest is also good this year
Offline Walnut Beast
« Reply #4 on: August 09, 2020, 11:13:40 AM »
Looks great👍
Offline farmfromkansas
« Reply #5 on: August 09, 2020, 11:21:51 AM »
Amazing straight logs you have there.  Do you use glue in the joints as well as pegs?
Offline trimguy
« Reply #6 on: August 09, 2020, 11:50:59 AM »
Very nice. Good job. Neat idea with the dowel pins.
Offline mike_belben
  • Pulp Friction
« Reply #7 on: August 09, 2020, 11:59:45 AM »
A swiss in costa rica doing amish joinery to build a shed from teak. Thats as unique as it gets!  Beautiful work.
Did you freehand that first 2 sided beam?
Revelation 3:20
Offline teakwood
  • Switzerland
« Reply #8 on: August 09, 2020, 12:50:21 PM »
Yes sir, i'm not bad at it i guess. it was alot easier afterwards on the sawmill, just slide back and forth and turn. no adjusting height, searching for the center, take out the slack,.....
Offline Tom King
    • HistoricHousePreservation
« Reply #9 on: August 09, 2020, 02:21:04 PM »
That's a nice looking piece of furniture you're building!
Offline teakwood
  • Switzerland
« Reply #10 on: August 10, 2020, 06:22:40 PM »
neee, as i will oil the parts completely disassembled with 2 coats of linseed oil the glue would not hold. i probably put a little glue on the pegs so they wont loosen in dry season
Offline teakwood
  • Switzerland
« Reply #11 on: August 10, 2020, 06:27:11 PM »
had a welder fabricate me some braces for the concrete/wood joint. expensive but i wanted them in inox steel.
these are the joints for the long beams
Offline mike_belben
  • Pulp Friction
« Reply #12 on: August 10, 2020, 06:33:35 PM »
Dang u werent playin around
Revelation 3:20
« Reply #13 on: August 10, 2020, 06:52:49 PM »
Looks very nice 👍 👍👍
« Reply #14 on: August 10, 2020, 06:56:54 PM »
We will see how your little puzzle fits together
Offline Brad_bb
« Reply #15 on: August 10, 2020, 07:18:07 PM »
Very nice cutting job!  Beautiful wood too!
Offline frazman
« Reply #16 on: August 10, 2020, 08:32:31 PM »
I like the grain on that wood. Nice clean joints. Excellent work.
Offline thecfarm
« Reply #17 on: August 11, 2020, 05:32:11 AM »
That wood looks good!!
As I say, use what you got!! be it wood or equipment.
Offline teakwood
  • Switzerland
« Reply #18 on: August 11, 2020, 08:21:38 AM »
These are fotos form the last 2 weeks, i held of with the start of the topic until i had something to show so you wont get bored.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #19 on: August 11, 2020, 02:49:15 PM »
Teak sure is beautiful.
Sawmillshed....info with electricity needed
Started by roger 4400 on Sawmills and Milling
Last post January 25, 2013, 04:17:36 PM
by davey duck
sawing Teak
Started by teakwood on Sawmills and Milling
Last post April 17, 2019, 05:25:16 PM
by olcowhand
Teak clearcut
Started by teakwood on Forestry and Logging
Last post May 18, 2016, 12:40:30 PM
by enigmaT120
Mahogany or Teak?
Started by Sawyerfortyish on Sawmills and Milling
Last post May 05, 2004, 11:28:32 PM
by DanG
