Dynamic Green Products Inc.
Author Topic: Woodmizer Alternator  (Read 939 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Woodmizer Alternator
« Reply #20 on: August 10, 2020, 07:08:30 AM »
No, Wood-Mizer buys alternators that meet their specifications.
barbender, my sawmill is a 1998 and came with the 140 amp alternator.  As I said previously, 1997 was a sorta mid-year thing and many changes/upgrades were made that year.
Offline barbender
« Reply #21 on: August 10, 2020, 07:54:04 AM »
Yep, Magic- my mill is the newer style frame, same as yours with the 2 plane clamp. Still has the older Mk 1 debarker. I don't know what other mix of new and old is on there, I guess I can add 105 amp alternator to the list😊
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #22 on: August 16, 2020, 12:06:01 PM »
     I'm late to this party, but just changed the alternator on my LT50 a couple of days ago.  It's a stock GM 140 amp alternator.  My regular vehicle mechanic got it from a local auto parts store.  (I used him 'cuz I got it for his price.)  Exact same as the one from WM.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Offline barbender
« Reply #23 on: August 17, 2020, 08:42:26 PM »
I ended up getting one from my local Carquest. It's their store brand, new manufacture 140 amp and lifetime warranty. I would've just ordered it from WM but I was in a pinch and needed it now. One problem I'm running into, is that the 140 amp puts enough of a load on the engine at idle that it slows it to the point that the alternator output is dropping I think (my hydraulics slow down). I'm going to try bumping my low idle up 100 rpm or so and see how that does.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #24 on: August 17, 2020, 09:59:31 PM »
My idle speed is ~1500 so the alternator is putting out over 14 at all times.
This is wired directly to the battery so I always know what the voltage is.  This 12.6 picture was taken after I installed it and without the engine running.
Offline barbender
« Reply #25 on: August 18, 2020, 01:00:31 AM »
I remember that mod, and it's an excellent one MM. I don't have a diesel tach on my engine, but an educated guess would be 900-1000 rpm as it sits on low idle.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #26 on: August 18, 2020, 09:43:02 PM »
My book says that mine should idle at ~1500.
Here is a picture taken today at idle.  14.5 volts.  The voltage changes very little from idle to sawing speed.
I have a manual tach that I hold to the end of the crankshaft.
Woodmizer alternator
Started by richie47 on Sawmills and Milling
Last post January 09, 2007, 07:44:02 AM
by richie47
Woodmizer alternator issues
Started by woodrat on Sawmills and Milling
Last post May 02, 2016, 05:58:46 PM
by OlJarhead
Woodmizer alternator current draw ??
Started by jcbrotz on Sawmills and Milling
Last post March 20, 2014, 09:06:30 AM
by sparks
Woodmizer lt40 alternator Problem
Started by sawmillhand on Sawmills and Milling
Last post August 09, 2014, 10:32:14 PM
by Lacplesis
