Dynamic Green Products Inc.
Author Topic: Size tractor?  (Read 1339 times)
Offline Bruno of NH
Re: Size tractor?
« Reply #20 on: August 21, 2020, 08:08:34 AM »
Pictures please
I like the Branson
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Al_Smith
Re: Size tractor?
« Reply #21 on: August 21, 2020, 08:53:18 AM »
You can drag logs with a Ferguson or Ford tractor but you had best chain the tires up . They are too small to pull stumps though .
Offline Nebraska
  • Lurked for quite a while, learning !
Re: Size tractor?
« Reply #22 on: August 21, 2020, 12:44:15 PM »
Congrats you'll get along well with the Branson. Should do almost everything you need.
Offline North to Alaska
Re: Size tractor?
« Reply #23 on: August 23, 2020, 03:58:11 PM »
Pics
Offline Bruno of NH
Re: Size tractor?
« Reply #24 on: August 23, 2020, 06:48:09 PM »
Very nice !
Offline PatMcD
Re: Size tractor?
« Reply #25 on: September 15, 2020, 02:06:53 PM »
Congrats on the new tractor.
But, I will chime in on brands in case somebody else reads through this for info:
I wouldn't wish a Long tractor on my worse enemy! I had a Long 460 DTC that was the worst piece of crap ever to come out of a factory. Bolts kept loosening up on the box on the side that powered the 4WD system. Go to tighten them (3/4" bolts) and they stripped out. Whatever Soviet-era, Romanian steel they used was incredibly soft. Snapped the actual 4WD drive gear inside that box when I was pushing a big boulder. The "final drive" system for the rear wheels will leave you scratching your head. Forget trying to keep a tach cable on it; it'll snap/strip within 2 hours. I could go on and on. Found a sucker down state that absolutely had to have it, so away she went. Bought a LS U5030 and am SO much happier.
Tractor size
Started by wbrent on Sawmills and Milling
Last post December 07, 2018, 07:58:34 AM
by wbrent
What size tractor
Started by haven1279 on General Board
Last post March 29, 2008, 10:47:39 PM
by WH_Conley
What size tractor do I need
Started by AndyB on Sawmills and Milling
Last post July 09, 2003, 04:00:47 PM
by Ron Scott
Best tractor size for the woods
Started by livemusic on Forestry and Logging
Last post January 08, 2020, 02:48:12 PM
by John Mc
