Dynamic Green Products Inc.
Author Topic: How much can a tractor winch pull?  (Read 681 times)
Offline shinnlinger
« on: August 13, 2020, 09:58:52 PM »
I did some horse trading for a used 367 Norse winch a few years ago. Canít find much info on that model.
  Iíve used it to haul more Volkswagen busses than logs but now that Iím actually using it in the woods Iím running up on its limits and wondering if itís out of adjustment, the clutch is worn or if itís just how it is.  My tractor only has 27pto hp, but the winch will hang up fairly easily.  Or at least I think so until I see I buried the log half in the dirt.  It seems 2 20 ft 20Ēdbh white pine is all it wants.  I can live with that but if I can turn a screw or replace a clutch I would do it.
Shinnlinger
Offline donbj
Re: How much can a tractor winch pull?
« Reply #1 on: August 13, 2020, 10:43:01 PM »
The model 350 pulls 8000lb, the 450 pulls 10,500lb so you're probably right in the middle
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline thecfarm
« Reply #2 on: August 14, 2020, 05:06:28 AM »
I'm not going too much help. I seen my tear up rocks and roots and dig the ground up and keep coming. Than sometimes it won't move the same size log.  ???
Don't know it you are trying to winch in both logs at once?
I only winch in one at a time, if they are that big.
Offline 47sawdust
« Reply #3 on: August 14, 2020, 05:42:14 AM »
I think you are probably maxed out for that size winch.
Mick
Offline shinnlinger
« Reply #4 on: August 14, 2020, 10:04:09 AM »
Could be.  The winch seems to work fine and obviously has a safety overload.   Iím just trying to determine if I have something wrong or itís working as it should.
Shinnlinger
Offline repmma
« Reply #5 on: August 18, 2020, 06:49:26 AM »
I concur with thecfarm, ive got the 450 behind a Ford 5030, 63hp pto and it can either plow thru boulders like its a super winch or snub up solid on just the smallest edge of a stump to the point it seems like two different sized winches some days.  But in general itll pull in much larger then i should be twitching out behind the ole ford on this land.
I just need to get my Timberjack repower project done and save the wear and tear on the tractor.
Thomas 8020, Timberjack 225C, Ford 5030 with Norse 450 winch, stihl saws and 142 acres to manage.
Offline Hilltop366
« Reply #6 on: August 18, 2020, 09:40:19 AM »
Sounds like your clutch is slipping?
If it is any thing like my winch (Norse 390) the leaver is spring loaded to limit the force on the engagement but the clutch can also be adjusted by tightening the large nut on the winch drum bolt. By tightening the nut you pull the frame together and reduce the clutch/drum clearance.
Offline billhook
« Reply #7 on: August 21, 2020, 03:31:37 AM »
Perhaps making some kind of cone at the front of the log like this fella did with an old plastic barrel,
or buy one from the portable winch company,
always good to look at this video and think about cab protection
https://www.youtube.com/watch?time_continue=970&v=97XqNX3yFTk&feature=emb_logo
Never had any problems with this Hyster on a Cat D7!
https://dcn6x9s7fzj11.cloudfront.net/monthly_2019_12/3FC41ABC-BD3B-4A64-82D2-5423F6E56644.MP4.3b43f8e1112cd057ee6ccde3811397de.MP4
how to increase winch pull
Started by pacodog on Forestry and Logging
Last post November 29, 2006, 06:24:32 AM
by mike_van
Hercules winch will pull until resistance
Started by Solo33 on Forestry and Logging
Last post July 18, 2019, 07:05:40 PM
by Thompson8821
question
Put a winch on the mill to pull logs?
Started by DR_Buck on Sawmills and Milling
Last post April 04, 2004, 12:47:20 PM
by Kevin_H.
Somethin' to pull my Tractor with!
Started by loudsam on Sawmills and Milling
Last post March 13, 2006, 08:54:14 PM
by barbender
