Author Topic: Husqvarna 346xp?  (Read 554 times)
Offline Rtpassini
Husqvarna 346xp?
« on: August 17, 2020, 09:59:18 PM »
So I'm newer to the "depth" of saws. Just have an off grid cabin that we use on the weekends. Bought a 440 new a few years ago. Even though I dont have a huge use for a saw now that most land that needed clearing is done I feel I outgrew the saw and am looking at other options. Found an 03 346xp for sale. Looks in nice condition. Case, chains and tons of other items for under 200 bucks. Just some random browsing it seems these saws are desirable especially with some mods. Thoughts? I was looking at ms291 or 455 for comparisons
Offline barbender
Re: Husqvarna 346xp?
« Reply #1 on: August 18, 2020, 01:01:49 AM »
If you haven't grabbed it already it's probably already gone. That's a highly sought after saw.
Offline sawguy21
« Reply #2 on: August 18, 2020, 11:10:16 AM »
X2. Deals like that don't often come along. I can't find a 346XP at any price.
Offline mike_belben
  • Pulp Friction
« Reply #3 on: August 18, 2020, 01:39:03 PM »
346xp is a nasty limbing saw.   acchilles heel is if it has the rubber/plastic clamp intake boot shared throughout the husky/jred 50cc class.
Revelation 3:20
Offline sawguy21
« Reply #4 on: August 18, 2020, 01:44:55 PM »
That is easy to change before it becomes a problem.
Offline mike_belben
  • Pulp Friction
« Reply #5 on: August 18, 2020, 03:14:15 PM »
Im pretty certain you have to lift the jug off the block to get that boot out of the register in the case.  Ive got one apart in the shed i will look at.
Revelation 3:20
Offline barbender
« Reply #6 on: August 18, 2020, 05:45:36 PM »
I changed the clamp on mine without loosening the jug.
Offline Spike60
« Reply #7 on: August 19, 2020, 06:23:37 AM »
A 2003 will have come with the plastic clamp. I've done a ton of these saws. It's much easier to pull the cylinder than to work in that tight space trying to avoid it. Just 4 bolts. Need to be sure that the impulse nipple on the boot properly fits into the hole in the cylinder. If the saw has much time on it, a new ring as it's going back together is a good idea too.
The % of those clamps that failed was pretty high, but there were plenty of them that didn't. Still see a lot of these saws coming into the shop. Quick check is to use your thumb and see if the clamp is loose or not. If it's tight I just leave it alone. If it's loose then I usually change it. Of course, attrition has taken it's toll over the years and most saws that had the clamp problem have failed by now. Any survivors with loose clamps tend to be the homeowner saws with limited hours on them.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Offline HolmenTree
« Reply #8 on: August 19, 2020, 08:16:55 AM »
I had a very low hour 346XP New Edition I bought new. Never had much use for it so gave it to my FILaw about 7 years ago. He only used it to cut a few willows since but won't give it up.
Now that I'm 62 yrs old I wish I kept it. :D
Offline old guy
« Reply #9 on: August 19, 2020, 09:03:50 PM »
I've got 4 of the little buggers, one of em has been touched by Scott Kunze, no! I will not part with em!
Offline mike_belben
  • Pulp Friction
« Reply #10 on: August 20, 2020, 12:02:28 PM »
I forgot all about this.
Anyone have the part number for whatever the latest and greatest improved intake boot is?  Hopefully one with a metal clamp.  I sorta wish they just used a hose clamp.
Revelation 3:20
Offline Spike60
« Reply #11 on: August 21, 2020, 06:40:35 AM »
Will look it up when I get to the store in about an hour Mike.
EDIT: Here ya go- 537 251 302
Husqvarna-Jonsered
845-657-6395
Husqvarna 346XP PHO
Started by Higgins on For Sale
Last post May 16, 2015, 12:18:34 PM
by kellysguy
Husqvarna 346xp vs echo 501sx
Started by gregorymk2 on Chainsaws
Last post February 28, 2019, 12:45:08 AM
by gregorymk2
Husqvarna 346XP compression release?
Started by jjmk98k on Chainsaws
Last post March 19, 2008, 11:41:00 PM
by letsgetitracing
Husqvarna 346xp, engine almost quites all of a sudden while cutting
Started by KBforester on Chainsaws
Last post May 10, 2015, 12:32:33 AM
by barbender
