Author Topic: Echo 155t oil pump repair question  (Read 139 times)
Offline caveman
  • In the land of the blind the one eyed man is king
« on: August 23, 2020, 10:58:04 AM »
We have a top handle echo 355t saw that has seen very little use, probably less than ten tanks of fuel have been run through it. Taking it back to the store is not an option as John and I were given this saw after helping his neighbor take down a large, troublesome oak in his yard.
I used the saw at school/work last week to trim a few trees. It quit oiling while running the second tank of fuel. Yesterday I dumped the bar oil and filled the oil tank with diesel (to clean it out) and it still would not pump. I disconnected the oil supply line from the pump and blew air through the tube into the tank with my mouth. Liquid flowed out of the oil tank through the tube.
Is there a way to repair the oil pump or should we just spend $50 and buy a new one?
As a side note. For a 35cc saw this thing has good power. Yesterday, after a slight modification to the muffler and enriching the high speed jet it would pull the chain on a 14 bar pretty well in hickory.
Caveman
Offline caveman
Re: Echo 155t oil pump repair question
« Reply #1 on: August 24, 2020, 05:57:22 PM »
Next question.  I found a replacement for much less money on Amazon.  Do any of you have advice on aftermarket oil pumps?
Caveman
question
Echo 27 bar question
Started by Bama Dan on Chainsaws
Last post April 29, 2020, 11:42:44 PM
by Iwawoodwork
Echo gas cap question.
Started by tractorfarmer on Chainsaws
Last post November 08, 2011, 01:30:20 AM
by tractorfarmer
Husqvarna HUV repair question
Started by Farmer Jim on General Board
Last post June 28, 2014, 04:06:21 PM
by Farmer Jim
repair question on older saw
Started by foresthawk on Chainsaws
Last post January 11, 2005, 09:29:42 AM
by johnjbc
