Author Topic: Stihl 009L Stop Switch  (Read 149 times)
Offline jbj53
« on: August 23, 2020, 03:33:30 PM »
I inherited a Stihl 009L that hasn't been run in at least 7 years.  It has no stop switch and I don't know if it will run at all.  I've been cleaning it and, before I fuel and oil it, then try to start, is the stop switch a Go/No-Go item to run this saw?  Will it run without the switch, and is there a way to stop the saw without the switch?  Thank you in advance.
Offline ZeroJunk
Re: Stihl 009L Stop Switch
« Reply #1 on: August 23, 2020, 04:46:37 PM »
You don't need the stop switch for the saw to run since all it does is short the ignition, the same principle as pushing the metal strap down on top of the plug on an old mower.  You can stop it with the choke forever, of find a replacement switch.
Offline jbj53
« Reply #2 on: August 23, 2020, 08:06:15 PM »
thanx... i'll put it together and see if it will run.  appreciate the help, couldn't figure out what the switch did or how it worked since it isn't there.
Offline ZeroJunk
« Reply #3 on: August 23, 2020, 10:07:33 PM »
The fuel lines and tank vent line that goes out under a little brass piece under the clutch cover are more than likely dry rotted. And, the carb will likely need to be rebuilt.
You can take a little mixed gas and pour it straight in the carb and see if the saw will run until that's gone.  That will tell you whether it has fire and enough compression to run before you chase your tail.
stihl 009l
Started by maybe smith on Chainsaws
Last post May 21, 2019, 11:23:54 PM
by maybe smith
Stihl 009L Still Running.
Started by Stihlowner on Chainsaws
Last post March 26, 2016, 01:05:56 PM
by VKJohnson
Control station...start/stop switch needed
Started by Larry on Wanted
Last post March 25, 2006, 08:05:44 PM
by Larry
Stihl 025 kill switch
Started by outdoortype on Chainsaws
Last post May 01, 2005, 09:54:54 PM
by fishhuntcutwood
