Author Topic: Ya値l said This would happen... and it did!  (Read 1756 times)
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Ya値l said This would happen... and it did!
« Reply #20 on: August 29, 2020, 02:49:20 PM »
So you hit metal and did the backwards blade thing, cool. Now roll a log off the backside of the mill and wedge it between the tire and frame and you will be well on your way to a Woodmizer Grand Slam award.  :D
And do it without  a loader to get it out.Extra points for that one  :D
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #21 on: August 29, 2020, 02:58:47 PM »
   The bigger the audience the more extra bonus points you get too. :D
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #22 on: August 29, 2020, 08:50:36 PM »
You can use pine or hardwood stickers as long as they are dry.  You can saw out a bunch of 1"x1" pine and sticker the stickers and run a fan on them full blast and in a matter of a few days you can use them.  With a fan on them they will dry enough pretty Dang fast.
Offline chinaberry
« Reply #23 on: August 29, 2020, 08:56:49 PM »
That is good info that I didn稚 know... thanks, I値l give that a try.  Seems like there are an unlimited number of ways to screw-up your fresh sawn lumber.
Offline Durf700
« Reply #24 on: August 30, 2020, 08:26:33 AM »
Congrats on the new mill!  I have the same and I love it!  you must have the manual middle backstops if you missed the first one?
I've nicked my backstop and log clamp a touch , popped off the blade coming back before I raised the head enough and have dropped an 8x8 off the back of the mill flipping it which wedged between the tire and frame..  but I havent put a blade on backwards yet!  :)
Offline chinaberry
« Reply #25 on: August 30, 2020, 01:01:51 PM »
Hey, Durf... you are correct my two middle backstops are manual.  My woodmizer dealer talked me out of going with the additional 2 Hyde backstops.  I知 glad he did.  I like it that way.
I really like the simple set... does all I need it to do.
I like the scale.  Easy to read, it being so close... and precise.
The scale reads in sixteenths, but you can actually just quickly bump the drum switch and it痴 possible to only move the head one thirty secondth.
The Kohler is great... runs fairly quietly, smooth, powerful, and starts like a new car... and easy maintenance.
Two things I don稚 like:
The debarker keeps throwing the circuit breaker... frustrating.
The sawmill jacks are a real pain.  Very hard to level the frame properly.
I値l be getting the fine adjust outriggers soon.
I have discovered that once you buy a sawmill, you池e just getting started spending money.  Just spent $296 on 13 oak and pine logs.
I absolutely love my mill... suits me just fine, for now.  Will be dreaming now to purchase an LT40 super hydraulic!!
« Reply #26 on: August 30, 2020, 02:21:59 PM »
CB,
   I am glad you are happy with your manual additional side supports. I am happy mine are hydraulic. To each his own. If I lower mine all the way with my hydraulic switch I don't have to remember if I lowered the 2 middle ones too.
   If the debarker is tripping I bet you are sawing from the small end and the pressure keeps increasing causing it to trip. There are pros and cons to which end you start from so basically it is just a learning curve as to how much pressure to apply so right now just keep bumping the in and out switch on the debarker as needed. It will become more automatic with time. I wish someone would design one that automatically followed the curve of the log applying the same pressure no matter the size of the log. Maybe WM will see this suggestion, build it and send me some of the extra money it earns them. :D
   The jacks, especially the two on the drive side, are a pain to operate. i keep an old car bumper jack I use. Actually, since nothing in WV is level anyway, I normally drive the low side up on 2-3 boards about 1"X6"X3' to help level the mill side to side and I carry an assortment of cut off 1X6 & 2X6 to put under the jacks. I'd rather raise my mill than dig it in but I keep weight on the tires.
   Since you are throwing money around everywhere anyway stop at a truck stop or RV center and buy yourself a pair of small sticky back levels like you put on RVs ($5-$6 probably). Mount them on the lower rails/supports so you can easily see when your mill is almost level end to end and side to side. Remember - your mill does not have to be perfectly level - just close and with weight on all the jacks.
   Yes, I love my SimpleSet. Accuset is better but SimpleSet if very good. I use it with my cheat sheet so I always land on a finished board on the bottom. I'm attaching a copy of it as a mill warming gift to you. :D I keep mine sealed in a gallon ziplock back with 2 small magnets from HF stuck on the inside cover of my control panel so it is always with the mill.
   Buying logs is a personal decision. I have 40+ acres of mostly wooded property so I cut what I need/want. People periodically give them to me or I trade for them. I have but very rarely paid for logs. My best deal so far this year was to trade a 5X8 trailer load of kindling cut from my slab pile for a walnut tree - 5-6 logs which returned over 265 bf of some real pretty walnut slabs.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #27 on: August 30, 2020, 02:50:58 PM »
When you are leveling up your mill, when you're adjusting the front jacks, move the sawhead to the rear and when you are adjusting the rear jacks, move the sawhead to the front!
In short, move the sawhead to the end you're not adjusting!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Durf700
« Reply #28 on: August 30, 2020, 03:05:24 PM »
I really like my fine adjust outriggers I copied from others on here.  I use my dewalt cordless drill and set it up and tear in down in a few minutes without tweaking my back!  about 450 dollars!  I have the extra backstops hooked into the factory hydraulic ones also and I like them that way.  as far as the debarker, yes, you either are cutting from the small end and building up pressure or your hitting some knobs that stick out on the log and it is working it extra hard.  I just bump it out and then back in as I go down the log to solve the issue.  I popped my breaker 1 time the 2cd day I used it.  haven't popped it since in the last 50 hours logged on the mill meter.
I bought mine June 6th with 192 hours on it , only mill on my 1 day off per week and have 245 hours on the meter now.
love my LT 35 Hydraulic with debarker!
Offline chinaberry
« Reply #29 on: August 30, 2020, 08:34:20 PM »
VW,
I was sawing from the small end.  I like being able to 都ee the ant size better.  I was trying to adjust the debarker out as I progressed thru the log, but you really can稚 see how much bite it is taking.  So, yes, I think it is worthwhile, for the debarker alone to saw from the big end.
On throwing money around... I certainly don稚 just throw money around.  My money is earned the hard way and I try to be sensible with what little of it I have.  Getting logs to mill is not so easy where I live in Plaquemines Parish, LA.  I only have roughly 75 trees that I can harvest off my property, so I want to be judicious with cutting them.  I have a full time job as an owner/operator truck driver... so I don稚 have a lot of free time chasing free logs.  Think about it... if I go into town 60 mile drive load 5 logs from three places, I致e burnt a day for $100 dollars of 吐ree logs.  I could have spent that day driving and had an opportunity to earn $500.
I purchased 14 logs for $296, or about $20/log.  I got them from a wood products reclamation yard.  They get varying types, sizes, and species of logs and if they are decent logs, they put them aside and try and sell them.
The thing about this, is I go right by this place, 3 or 4 times a week driving my hotshot 36 gooseneck trailer.  90% of the time, I pass by deadheading.  So I just swing in off the hiway, choose what I want, they load me up, and I知 back on the road, having made good money on my truck run.  Pretty good deal.  As I progress, and learn more, I hope to make a number of good contacts for logs.  We will see.
Chuck,
Why didn稚 I think of that?
Durf,
Brought my mill home 8/14... have 38 hrs on the clock.  You guys kill me, always tinkering, and modifying your mills. I want to keep mine stock!  I will get the WM fao痴.
Offline chinaberry
« Reply #30 on: August 30, 2020, 08:37:51 PM »
WV,
I almost forgot... the 田heat sheet.  Thank you so much for sharing it with us.  That took time and a lot of effort... koodos!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #31 on: August 30, 2020, 08:44:54 PM »
I'm not sure that I would like that style Debarker's rotation direction.  It's "diggin in" where mine is "climbing out".  There is a disc that can be added to prevent the blade from digging in deep enough to trip the breaker.  I also seem to remember that some have reversed the blade direction, maybe not??  Anyway, I would call Wood-Mizer and talk with technical support.
Offline richhiway
  • Rich
« Reply #32 on: August 30, 2020, 08:51:48 PM »
Good Luck with the new mill.
I think he was kidding you about throwing $ around.
You don't need to "jack up the mill". They are supports not jacks. Like above you use the head to take the weight off. The mill should still be sitting on the tires, but level.
That may not apply in W.V.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline Banjo picker
« Reply #33 on: August 30, 2020, 09:24:06 PM »
They already have Howard, it痴 just on a Cooks.  Tim
Offline GAB
« Reply #34 on: August 30, 2020, 09:28:50 PM »
There was a thread about reversing the direction of the debarker not too awful long ago.  If memory serves me correctly it involved changing some wiring.
GAB
« Reply #35 on: August 30, 2020, 09:32:13 PM »
Banjo,
   That was fast! When are they going to send me my check? :D :D
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #36 on: August 31, 2020, 12:15:20 AM »
TT,
   Did most of us just get insulted there? Are you trying to incinerate sumpin? :D :D
Amended and clarified above..... feel like I pulled a Bilbo Baggins at his going away party..... :D :D :D
Offline BandsawBen
« Reply #37 on: September 09, 2020, 07:34:54 PM »
I hit my backstop yesterday,  ive hit it before but this time i hit it hard.  Almost all the way through
Offline trimguy
« Reply #38 on: September 09, 2020, 08:04:26 PM »
It痴 ok, the shiny was wore off the bolt, you need a new one anyways. :D :D
Offline WDH
« Reply #39 on: September 09, 2020, 08:10:16 PM »
That blade will make the Hall of Fame :D
*&%$*& Why does it always happen to me?
Started by Rick Schmalzried on General Board
Last post August 28, 2002, 11:07:02 PM
by whitepe
Has this happen to you?
Started by fishfighter on Sawmills and Milling
Last post August 09, 2016, 11:36:27 PM
by BUGGUTZ
They said it could happen......
Started by Jim_Rogers on Sawmills and Milling
Last post January 22, 2009, 07:17:45 AM
by petefrom bearswamp
laugh
Anyone had this happen?
Started by Oregon_Rob on Chainsaws
Last post January 14, 2004, 01:57:15 PM
by L. Wakefield
