Dynamic Green Products Inc.
Author Topic: Ya値l said This would happen... and it did!  (Read 1758 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Ya値l said This would happen... and it did!
« Reply #40 on: September 09, 2020, 08:47:41 PM »
You need to use a harder grade of bolts.  ::)
Offline Southside
    • White Oak Meadows
« Reply #41 on: September 09, 2020, 08:58:42 PM »
Replace it with a carriage bolt, just need to round off the shoulders, it works perfectly and gains you over 1/4" more forgiveness room.
On the advice of counsel I must invoke my 5th Amendment right and can not speak to how many bolts may or may not have been modified in such a similar manner before the carriage bolt mod was completed.   ;D
White Oak Meadows
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #42 on: September 12, 2020, 05:21:16 AM »
Maybe try a wood bolt.  :P
See Here
Offline Cedarman
    • Cedarusa
« Reply #43 on: September 12, 2020, 07:20:43 AM »
Those teeth gave their all trying to get through that bolt.  But, alas, no success.  Maybe next time.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #44 on: September 12, 2020, 07:56:23 AM »
The debarker keeps throwing the circuit breaker... frustrating.
I talked to WM about my debarker always tripping, they asked if the disk was on? yes.
Next they sent me a new circuit breaker, reason being a circuit breaker trips to often, they get weak and then trip easier each time.
I put on the new CB and the debarker is running all the way down the log. I also keep my finger off the toggle, I stopped holding the debarker into the log..
Offline teakwood
  • Switzerland
« Reply #45 on: September 12, 2020, 08:11:45 AM »
If you make 25 passes on the sharper you can maybe address that band again!
Offline Banjo picker
« Reply #46 on: September 12, 2020, 08:20:51 AM »
If you of been going just a little bit faster........Tim
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #47 on: September 12, 2020, 10:55:57 AM »
It値l buff out.
YellowHammerisms:
Take steps to save steps.
If it won稚 roll, its not a log; it痴 still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, they池e burned, and you can稚 fix them.  Don稚 burn the cookies.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #48 on: September 12, 2020, 08:00:25 PM »
Probably will cut better backwards :)
They said it could happen......
Started by Jim_Rogers on Sawmills and Milling
Last post January 22, 2009, 07:17:45 AM
by petefrom bearswamp
laugh
Anyone had this happen?
Started by Oregon_Rob on Chainsaws
Last post January 14, 2004, 01:57:15 PM
by L. Wakefield
Y'all ever have this happen?
Started by DanG on Technical Support Topics
Last post May 11, 2009, 06:04:34 PM
by Chuck White
I saw it happen
Started by Magicman on Sawmills and Milling
Last post July 01, 2015, 10:12:38 PM
by WDH
