Author Topic: Log Splitter Project in Eastern NYS near Albany  (Read 1102 times)
Offline thecfarm
Re: Log Splitter Project in Eastern NYS near Albany
« Reply #20 on: September 04, 2020, 10:19:22 PM »
Yes, I saw that too. Or think I do. Maybe that's the problem??  ???
Online Walnut Beast
« Reply #21 on: September 04, 2020, 11:56:21 PM »
Is anybody familiar with TM SKIDSPLITTER PRO
Offline Old Greenhorn
« Reply #22 on: September 05, 2020, 05:54:21 AM »
Only slightly. That is a typical skid steer splitter that works 'upside down', correct? Not sure how that relates to this splitter. What am I missing?
[EDIT]
Oh wait, I see, you are saying this was built from one of the skid steer splitters and now that I look at it, I believe you could be right! I thought you were referring to the question of how does it work. The 'builder' was probably trying to find a way to free up his skid steer and improve throughput.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Online Walnut Beast
« Reply #23 on: September 05, 2020, 06:01:11 AM »
Just wondering since there is many of you guys splitting wood
Online gasman1075
  • I'm lucky
« Reply #24 on: September 08, 2020, 08:20:23 AM »
I will take some more pictures later today. I got the hydraulic pump off and scrounged a PTO adapter so I am going to replace some hoses and the main splitter valve. Then try and run it off the tractor PTO. The push block is shaped like a key hole and should travel the length with out hitting the v-block log support. I have lots of interest but not serious interest. So for now I will just keep working on it and see if I can get it running. The engine appears to be seized up tight but PB blaster and worked on loosening pump bolts and hydraulic valves and lug nuts. I will pull the spark plugs and try blaster in there ? Replacing the wheels and tires is next so I can bring it up near the house to work on instead of the field.
JD 2302R/Stihl MS461/Stihl MS261/ Timberwolf TW-P1/ new left hip /
Online gasman1075
  • I'm lucky
« Reply #25 on: September 14, 2020, 10:10:00 AM »
If I could get somewhere around $900 for this thing I would break even. Its so heavy I cant get the axles off the ground so I can replace the tires. It would need to be winched onto a flat bed but the field is flat and dry so easy to get to. Motor is seized. If no one local is interested I will just keep putzing around with it.  I hope removing the seized engine will make it light enough to jack up.
Thanks all.
** I have read and understand and rules regarding posting an item for sale on FF and agree to abide by them. **
moved
MOVED: Log Splitter Project in Eastern NYS near Albany
Started by Southside on Firewood and Wood Heating
Last post September 03, 2020, 02:14:05 PM
by Southside
Large Eastern White Pine Project
Started by Stephen1 on Sawmills and Milling
Last post December 15, 2019, 08:57:56 PM
by Magicman
My log splitter project - Input needed
Started by bmcdowell40 on Firewood and Wood Heating
Last post March 13, 2014, 05:49:19 PM
by Cguignard
Albany Resaw Mill
Started by tburch on Sawmills and Milling
Last post November 04, 2015, 07:04:51 PM
by bkaimwood
