Author Topic: DC Electrician Needed  (Read 879 times)
Offline dsgsr
« on: September 08, 2020, 04:08:46 PM »
I have a 2k lb. winch that raises and lowers the head on my sawmill. Having problems with the relay's. Only one works, I have bought numerous relay's to try and none work. I have one relay that works (in either slot)???   It's a Badland winch.
Thank you for any help,
David
Northlander band mill
Kubota M59 TLB
Takeuchi TB175 Excavator
'08 Ford 550 dump
'87 International Dump
2015 Miller 325 Trailblazer Welder/Gen
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Re: DC Electrician Needed
« Reply #1 on: September 08, 2020, 05:08:53 PM »
Many relays have a schematic printed on the housing. Compare the one that works with the ones that are not working. They may be wired different.
mh
Higher than my expectations
Offline Al_Smith
« Reply #2 on: September 08, 2020, 05:19:15 PM »
Most if not all relays made in the last 50 years have a brand name and a part number .That's the simple way to do it .Google will find it .
Offline mtmeatpole
« Reply #3 on: September 08, 2020, 05:33:12 PM »
Is it that the relay is not working or the winch won't work in one direction or the other? I feel like there is some needed info missing to help you out.
Offline Al_Smith
« Reply #4 on: September 08, 2020, 06:19:41 PM »
It's nearly impossible to trouble shoot anything over the internet .
Offline esteadle
    • Steadwood Forest Products
« Reply #5 on: September 08, 2020, 06:30:32 PM »
Badland winches are disposable.
If this one isn't working, dispose of it and get a new one.
They are half the price of a proper winch for a reason, and it ain't because they're reliable.
Offline tylerltr450
  • Trust me I run SAP and a sawmill
« Reply #6 on: September 09, 2020, 02:32:38 PM »
Relays are the simplest form of switching.
What you need to look at is voltage and amp load in order to size the relay correctly. Also you need to know which kind of schematic NO, NC. Attach images so someone can help.
Timber Harvester 36HTD25 fully loaded
2006 Dodge 2500 first Auto to NV5600 swap, EFI Live Tune by me
John Deere Tractor
Massey Ferguson 3200B SkidSteer
Offline donbj
« Reply #7 on: September 10, 2020, 12:03:15 AM »
Just like those knock off chain saws!
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline Iwawoodwork
« Reply #8 on: September 10, 2020, 01:02:38 AM »
I have had a HF 12000# winch on my Goose neck 12 ton trailer that has been great.
I have loaded 2 4x4 dump trucks , 2 loaders, a case w9, a Hough HM 4x4 all non running plus skidded a 16' refer box up on the trailer using 30' - 50' of line each time and still working good.
Offline Walnut Beast
« Reply #9 on: September 10, 2020, 01:57:41 AM »
A hauler a few years back came and picked up a truck I sold. He asked where the HF store was to return one of there winches. It was his 3rd one in a short amount of time. He wasnt happy
Online charles mann
« Reply #10 on: September 10, 2020, 02:09:26 AM »
same here. but due to my error, i burned the brake out, but for $350, i was extremely happy with my 12k. it did much better than my warn 16k.
Temple, Tx
Offline dsgsr
« Reply #11 on: September 12, 2020, 04:36:51 PM »
Thank you all for the replies. The original relays do not have any outside markings whatsoever. About 5-yrs. ago one of the original relays went and the local CarQuest guy found one on Amazon. It worked fine until this yr. It's a GAMA, it shows the pole arrangement. I bought the same item at GAMA through Amazon, same pole configuration it still doesn't work.
If I take the relay that works (it's and original) and put it in one of two spots to make the winch turn, it works fine in both directions.
Why aren't the new relays working. I have tried different brands (JD, Picker and GAMA).
You are absolutely right. but I'm hoping.
Thank you All again
David
Kubota M59 TLB
'08 Ford 550 dump
Offline mtmeatpole
« Reply #12 on: September 12, 2020, 05:32:15 PM »
If you have the power and ground for the switch on the relay(the small wires and some relays ground through the body) the only other thing needed is to connect the heavy wires and if it don't work it has to be the relay. If you can put the original relay in that position and it works I would be looking at the ground for the switch side most likely. Maybe the old one grounded through the body and the new one would require a ground wire. If its not that the relay is bad.
Offline DennisK
« Reply #13 on: September 12, 2020, 08:37:31 PM »
Is this a 5 pole or 4 pole relay?
Offline dsgsr
« Reply #14 on: September 13, 2020, 09:25:49 AM »
5 pole.
Kubota M59 TLB
'08 Ford 550 dump
Offline mike_belben
  • Pulp Friction
« Reply #15 on: September 13, 2020, 01:29:36 PM »
Small 2 pole winches just need a polarity change to reverse direction so what you need is a "reversing contactor."
Pull the controller off and use jumper cables direct from battery to winch terminals.  If it works right in each direction the winch motor is good. Toss the controller, buy a reversing contactor and a momentary 3 position on/off/on toggle switch.  You put 12vdc power to the center leg and control the contactor with that.  Google for a wiring schematic very simple.
Buy DB electrical pn LRW6000 for $20.
Revelation 3:20
Offline dsgsr
« Reply #16 on: September 13, 2020, 03:59:00 PM »
Thank you Mike. What I don't understand, The one original relay (that works) will make the winch work in either port, forward and back. It's acting like the new relay's are no good. But how could I have 6 bad relay's from 3 diff. companies all within 3-months from each other.
Thanks again,
David
Kubota M59 TLB
'08 Ford 550 dump
Online trimguy
« Reply #17 on: September 13, 2020, 04:06:16 PM »
They were all made in the same factory, just different brand names. I ran into that with auto alternators about 3 years ago.
Online btulloh
« Reply #18 on: September 13, 2020, 04:40:17 PM »
That doesnt mean they are the correct relays though.
Use an ohm meter and find the coil pins for the original that works.
Then use a 12v source to actuate the relay and use the meter to figure out the contacts. Do that actuated and non-actuated. Make a diagram as you go.
Then use the same method to check out the new relays. Youll probably find theyre different.
Using the diagram you made of the working relay you can buy the correct replacement.
HM126
Offline LaneC
  • Traveling Man
« Reply #19 on: September 16, 2020, 11:12:00 PM »
   From what I gather, 1 relay will work correctly in each direction. I would disconnect the power source, take the relay base off and look at the connections on the  relay base. I understand that it works when the relay is inserted into the base but check it. Sometimes (especially with DC,) you get what we call an DGEM. (dad gum electrical miracle :D). Just check the base and I hope that will fix it.
Man makes plans and God smiles
Anybody know a GOOD electrician???
Started by Fla._Deadheader on Sawmills and Milling
Last post March 28, 2004, 03:09:38 PM
by Fla._Deadheader
Much needed help/info needed-230TJ
Started by riverlogger on Forestry and Logging
Last post February 14, 2014, 07:24:58 PM
by riverlogger
Help needed LT-15
Started by John S on Sawmills and Milling
Last post May 05, 2009, 12:38:23 PM
by John S
help needed
Started by bedway on Sawmills and Milling
Last post July 09, 2006, 06:29:09 AM
by Percy
