Dynamic Green Products Inc.
Author Topic: Roller guides  (Read 191 times)
Offline hopm
Roller guides
« on: September 12, 2020, 06:28:11 PM »
Should guide bearings build up heat?
Offline charles mann
Re: Roller guides
« Reply #1 on: September 12, 2020, 07:51:50 PM »
Short answer, yes. But what are calling heating up, warm to the touch or blistering to the touch?
Home built or factory built?
Rated speed of bearing installed, sealed or require greasing, type of grease, under or over greasing can causing higher than normal temps.
Temple, Tx
Offline hopm
Re: Roller guides
« Reply #2 on: September 13, 2020, 12:10:31 AM »
Just warm to the touch. Thanks for the reply!!
Roller guides vs. Block guides
Started by mobile demensia on Sawmills and Milling
Last post June 09, 2013, 12:31:53 AM
by mobile demensia
Roller guides
Started by bandmiller2 on Sawmills and Milling
Last post July 29, 2012, 07:48:43 AM
by NMFP
roller guides
Started by AtLast on Sawmills and Milling
Last post June 17, 2003, 07:31:23 PM
by Neil_B
wm roller guides
Started by sabre_tooth on Sawmills and Milling
Last post March 26, 2004, 04:26:36 PM
by KILROY
